- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Auto offset for selected items
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I wish to have a lisp than enable to do automatic offset base on some selection of lines ,circles or polylines object as shown in attachment. Does anyone have idea on it?
Re: Auto offset for selected items
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
perhaps something like
(defun c:test (/ dist ent curve pt1 pt2 pt3 pt4) (vl-load-com) (setq dist (getdist (strcat"\nEnter Distance to Offset: <" (rtos (getvar "offsetdist") 2 2 ) ">:"))) (if (not dist) (setq dist (getvar "offsetdist"))); end if (setq ent (entsel "\nSelect Object to Offset:")) (setq curve (vlax-ename->vla-object (car ent))) (setq pt1 (vlax-curve-getClosestPointTo curve (cadr ent))) (setq pt2 (vlax-curve-getPointAtDist curve 0.01)) (setq pt3 (polar pt1 (+ (angle pt1 pt2) (* pi 0.5)) 1)) (setq pt4 (polar pt1 (- (angle pt1 pt2) (* pi 0.5)) 1)) (command "_.offset" dist (car ent) (osnap pt3 "_non") "") (command "_.offset" dist (car ent) (osnap pt4 "_non") "") (princ) )
Hope that helps
Henrique
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
lai wrote:I wish to have a lisp than enable to do automatic offset base on some selection of lines ,circles or polylines object as shown in attachment. Does anyone have idea on it?
(defun c:osd ( / ss e )
(setq ofd (cond
((getdist (strcat "\nEnter Offset distance"
(if ofd (strcat " <" (rtos ofd) ">: ") ": ")
)))(ofd))
(if (setq ss (ssget ":L"))
(repeat (sslength ss)
(setq e (vlax-ename->vla-object (ssname ss 0)))
(if (vlax-method-applicable-p e 'Offset)
(mapcar '(lambda (o)
(vl-catch-all-error-p
(vl-catch-all-apply
'vla-offset (list e o))))(list ofd (- ofd)))
(ssdel (ssname ss 0) ss)))
(princ)
HTH
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
pbejse,
very nice approach!
Cheers
Henrique
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here's my version from a couple of years ago. It remembers the offset distance used in it, separately from regular Offset's setting, and offers it as a default on subsequent use. But if there hasn't been a value used in it yet, it offers regular Offset's setting as a default [provided it's not Through, which would be inapplicable].
If you put Offset Both Sides or something similar in the Search window, you'll find a variety of threads on the subject [including one with an earlier version of the attached].
If you want to select all objects to Offset both ways at once, instead of one at a time, it could certainly be adjusted to do that.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
hmsilva wrote:pbejse,
very nice approach!
Cheers
Henrique
Thank you Henrique, its from an old routine of mine. Glad you like it.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Dear Henrique,
Thanks for your help..after test, i feel that it lack of some feature..
More prefer to pbejse lisp..Works more better.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Glad it helps
Cheers ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I fully agree with you, pbejse's code is a great code.
Cheers
Henrique
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi pbejse,
I not sure if the lisp can be modify to do it to be as shown in attachment.
