Yes, by using the tag strings in the attributes. I'm not really
good with macros, but ours looks like this:
Assembly:
'RowNum = 2
For Each elem In mspace
With elem
If StrComp(.EntityName, "AcDbBlockReference", 1) = 0 Then
If .HasAttributes Then
Array1 = .GetAttributes
RowNum = RowNum + 1
For Count = LBound(Array1) To UBound(Array1)
'excelSheet.Cells(RowNum, Count + 1).Value = Array1(Count).textstring
' The following lines will save the value of each arrays textstring and _
write it to the selected row and column. To put this macro back to the way _
it was originally, just comment the following lines and un-comment _
the above single line.(k.a. 1-15-98)
mknum = Array1(0).TextString
tagstring = Array1(Count).tagstring
If tagstring = "PART/DWG" Or tagstring = "DWG#" Then 'Found the Title Block
RowNum = RowNum - 1
GoTo 15
End If
If tagstring = "TAG" Then ' found a Machine Mark Block
RowNum = RowNum - 1
GoTo 15
Our Excel sht headers match the tags in the attributes of the bill of materials. I can send you the entire excel file with the macro if you'd like. Just let me have your e-mail. Maybe you
can look at it and tell more. HTH 🙂
