(setq Sel (nentsel "\n Select attribute entity: "))
(setq EntData (entget (car Sel)))
(setq EntData (subst (cons 370 -1) (assoc 370 EntData) EntData))
(entmod EntData)
(entupd (cdr (assoc -1 EntData)))
The above worked for me, but I noticed that once it was changed to '-1' the
dxf code isn't there anymore, so you would have to use the 'append' function
to add it. That may be your problem.
Tim
"A blind man lets nothing block his vision."
wrote in message news:5414400@discussion.autodesk.com...
I am trying to modify attribute's lineweight with hard coded colors based on
an existing CTB. I am creating a selection set and processing only those
attributes with code 62 present. I having trouble getting code 370 for the
attributes. This code (setq eLwt (cdr (assoc 370 eList)) returns nil and the
entmod don't do anything. I know code 370 will return -1 for ByLayer, -2 for
ByBlock and -3 for Default. What I am doing wrong? Is the 370 code
accessible through Autolisp or do I need to use Vlisp to access it?. Any
help will be appreciated. Here is part of the code:
(defun C:ChgAttLW (/ ss sslen ct blk ent eList)
(setq ss (ssget "x" '((0 . "INSERT")))
ct 0
sslen (sslength ss)
(while (< ct sslen)
(setq blk (ssname ss ct)
ent (entnext blk)
eList (entget ent)
(while (and ent (= (cdr (assoc 0 eList)) "ATTRIB"))
(if (assoc 62 eList)
(progn
(setq eClr (cdr (assoc 62 eList))
(GetClrLW)
(setq eList (entmod (subst (cons 370 LinW) (cons 370 eLwt) eList)))
(entupd ent)
(setq ent (entnext ent))
(setq eList (entget ent))
(setq ct (1+ ct))
(princ)
Alex
