Visual LISP, AutoLISP and General Customization
Valued Contributor
Louis-MarieGuerin3807
Message 1 of 8 (220 Views)
Attribute or field
220 Views, 7 Replies
01-17-2013 08:07 AM
Is it possible to make an attribute or a field in a template with page numbering for layouts?
Is it possible to make an attribute or a field in a template with the name of the layout?
Louis
*Expert Elite*
Alfred.NESWADBA
Message 2 of 8 (201 Views)
Re: Attribute or field
01-18-2013 07:48 AM in reply to: Louis-MarieGuerin3807
IMHO not without development, because AutoCAD has no property "page number".
you can show the current layout when using CTAB sysvar to be shown.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
pbejse
Message 3 of 8 (199 Views)
01-18-2013 07:59 AM in reply to: Alfred.NESWADBA
- alfred -
Watch out for multiple layout tabs when using fields.
*Expert Elite*
Alfred.NESWADBA
Message 4 of 8 (195 Views)
01-18-2013 08:09 AM in reply to: pbejse
When you create a field (showign CTAB) in each layout and you activate this layout (or you plot it) the field always shows the correct value.
Or do I understand anything wrong? What do you mean by that "watch out"?
- alfred -
Alfred NESWADBA
*Expert Elite*
pbejse
Message 5 of 8 (191 Views)
01-18-2013 08:19 AM in reply to: Alfred.NESWADBA
- alfred -
Yes you are correct. I should've said when using publish command.
Most companies i know tends to use publish especially with multiple layout tabs and it always messed up the sheet numbers when using field values.
*Expert Elite*
Alfred.NESWADBA
Message 6 of 8 (184 Views)
01-18-2013 08:44 AM in reply to: pbejse
I just have it tried (only to be more than sure):
  • Started AutoCAD 2013 SP1.1 German x64
  • goto Layout 1
  • created a text containing a field with the content of CTAB
  • goto Layout 2
  • copied the layout twice
  • marked the layouts "Layout 1" to "Layout 2 (3)"
  • started command _PUBLISH, set to PDF (not using background plot)
  • ...and find the result attached :smileywink:
But you are right, in previous AutoCAD releases that fields were not updated when plotting. So to be careful and verify that fields after plotting is necessary.
- alfred -
Alfred NESWADBA
*Expert Elite*
pbejse
Message 7 of 8 (177 Views)
01-18-2013 08:58 AM in reply to: Alfred.NESWADBA
- alfred -
I see, Good to know its not going to be a problem in newer versions of Autocad .
Cheers
Valued Contributor
Message 8 of 8 (167 Views)
Re : Attribute or field
01-18-2013 10:23 AM in reply to: Louis-MarieGuerin3807
Thank you all
:catvery-happy:
You are not logged in.
Announcements
Need installation help?
Ask the Community
