I'm looking a program that will put a xref attachment onto a specified layer. One layer for Modelspace xrefs and another layer for Paperspace xrefs. I'v seen some post here that uses a command reactor to specify the layer once the xref command executes, But, can this be done with (2) layer references?
Thank you in advance.
Solved by pbejse. Go to Solution.
@JLin631 wrote:I'm looking a program that will put a xref attachment onto a specified layer. One layer for Modelspace xrefs and another layer for Paperspace xrefs. I'v seen some post here that uses a command reactor to specify the layer once the xref command executes, But, can this be done with (2) layer references?
Go grab that reactor routine you found and stick this in there in the part where layer name is assigned to the xref object..
Something klike this:
(setq XrefLayer
(if (zerop (getvar 'Tilemode))
"PSLayer" "MLayer"));<--- whatever the name of your layer
or
(setvar 'clayer
Also depending on your approach you may need to check if the layer exist..
HTH
pbejse,
I've added the lines you've suggested to the area where the commands and layers are defined. But the program doesn't work after the modification. I think you've given me a direction in which I need to go. Thanks.
@JLin631 wrote:pbejse,
I see, hang on, i'll write a quick one for you.
EDIT:
Try this
(vl-load-com) (if xrf (vlr-remove xrf)) (setq xrf (vlr-command-reactor nil '((:vlr-commandWillStart . SetLayer)))) (defun SetLayer (cr ec / ln) (if (and (member (nth 0 ec) '("XREF" "-XREF")) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 (setq ln (if (zerop (getvar 'Tilemode)) "PSLayer" "MLayer"))) (cons 70 0))) ) (setvar 'Clayer ln) ) (princ) )
Change the layer name of the layers , of course you already know that.
HTH
One disadvantage of an incomplete reactor based solution is that things might not be resolved after the command. This is more complete but may not be fully complete. It accomodates restoration at the end and the possibility that the command will be cancelled. I have also tested it with "undo" and it seems to have no problems.
;;Command Reactor for Xref layer ;;D.C. Broad 2012 (if (null myxr-react) (setq myxr-react (vlr-command-reactor nil '((:vlr-commandwillstart . myxr-swaplayer) (:vlr-commandended . myxr-restorelayer) (:vlr-commandcancelled . myxr-restorelayer)))) ) (defun setormakelayer (layn doc) (if (null (tblsearch "layer" layn)) (vla-add (vla-get-layers doc) layn)) (setvar "clayer" layn) ) ;;commandwillstart callback (reactor commandlist) (defun myxr-swaplayer (r cl / doc) (if (member (car cl) '("XATTACH"));allowance for other commands (progn (setq doc (vlr-document r)) (vlr-data-set r (getvar "clayer")) (if (= 1 (vla-get-activespace doc)) (setormakelayer "ms_xrlayer" doc) (setormakelayer "ps_xrlayer" doc) )))) ;;commandended callback (reactor commandlist) (defun myxr-restorelayer (r cl) (if (and (member (car cl) '("XREF" "XATTACH")) (vlr-data r)) (setvar "clayer" (vlr-data r)) (vlr-data-set r nil) ) )
@dbroad3 wrote:One disadvantage of an incomplete reactor based solution is that things might not be resolved after the command. This is more complete but may not be fully complete. It accomodates restoration at the end and the possibility that the command will be cancelled. I have also tested it with "undo" and it seems to have no problems.
Good thinking, I like it.
Thanks dbroad
Cheers
