Kent1Cooper
Message 11 of 18 (219 Views)
Re: Assign variable if item is a member of a list?
01-19-2013 05:51 AM in reply to: mid-awe
Without loading it up and trying it, I suspect what you need to do is to change this section:
     (cond
       ((foreach PLANT PALM (member PLANT PALM)) "PALM")
       ((foreach PLANT TREE (member PLANT TREE)) "TREE")
       ((foreach PLANT SHRUB (member PLANT SHRUB)) "SHRUB")
to just this:
     (cond
       ((member PLANT PALM) "PALM")
       ((member PLANT TREE) "TREE")
       ((member PLANT SHRUB) "SHRUB")
Kent Cooper
pbejse
Message 12 of 18 (217 Views)
01-19-2013 06:24 AM in reply to: mid-awe
So you basically want to  process every item on the list if and only if the block associated with the list exists on the drawing session
Here's a demo: You may need to add your list before you try this code :
(Defun c:demo ( / MasterList Palm Tree shrub dictname)
(vl-load-com)
;;;	This section will create a master list filtering out items  	;;;
;;;	if the block does not exist in the drawing session		;;;
(if  (setq MasterList (mapcar 'cadr
	(vl-remove-if-not
	  	'(lambda (i)(tblsearch "block" (car i)))
	        '(("Palms_DYN" PALM) ("Tree_DYN"  TREE)("SHRUB_DYN" SHRUB)))))
;;;	This section will iterate thru the remaining list variables	;;;
  	(foreach lst MasterList
          	(setq dictname (vl-symbol-name lst))
          	(foreach key (eval lst)
                  	(princ (strcat "\n" key ": " (rtos (dict-get dictname key) 2 0)))
  (princ "\nBlocks Not found")
  (princ)
HTH
Valued Mentor
martti.halminen
Message 13 of 18 (201 Views)
01-21-2013 03:19 AM in reply to: Kent1Cooper
Kent1Cooper wrote:
But you're not correct about the second problem, though I grant that it might be better not to use that word as an argument, just to avoid any possible confusion.  "List" as used there is not a variable in the usual sense [there is no (setq List ...) happening], but rather a place-holder argument inside the (foreach) function.  Yes, the AutoLISP Reference describes it as assigning each item to a variable named for the 'name' argument, but it's not in the same way as (setq) does it.  Think of it as being like a localized variable in a (defun)'d routine or command, in that it has no meaning, nor any effect on anything else, outside the (foreach) function in which it is used.  It does work.  If I do this:
(setq ListA '(1 2 3) ListB '(4 5 6) ListC '(7 8 9))
and then run that routine, removing the [...etc....] part from the top line, and using [for example] 6 for YourItem, it puts into VariableForUseLater the correct list:
!VariableForUseLater
(4 5 6)
And similarly finds the correct list with other YourItem values.  And it has no effect on the (list) function, which continues to function normally afterwards.
I don't know the compiler internals, but running the interpreter in the VLIDE Console window I seem to be getting
different results:
$ (setq lista '(1 2 3) listb '(4 5 6) listc '(7 8 9))
(7 8 9)
_$ (setq MasterList (list ListA ListB ListC))
((1 2 3) (4 5 6) (7 8 9))
_$ (foreach List MasterList
  (if (member YourItem List)
    (setq VariableForUseLater List)
  ); if
); foreach
; User warning: assignment to protected symbol: LIST <- (1 2 3)
_1_$
LOG Trace stack
<1> :smileytongue:ROTECT-ASSIGN LIST := (1 2 3)
[2] (FOREACH ...)
[3] (#<USUBR @2c4512d0 -top->)
<4> :USER-INPUT (foreach List MasterList
        (setq VariableForUseLater List)))
<5> :CALLBACK-ENTRY
[6] (C:VLIDE)
<7> :CALLBACK-ENTRY
- On the other hand, the assignment disappears outside the FOREACH call, so this would only produce an error if I tried to call the LIST function inside the FOREACH loop:
_$ (foreach list '((1)(2)) (print (list list)))
; User warning: assignment to protected symbol: LIST <- (1)
_1_$
; continue after break loop
; error: bad function: (1)
_1$ list
(1)
_1$
; reset after error
_$ list
#<SUBR @28058e08 LIST>
Kent1Cooper
Message 14 of 18 (189 Views)
01-21-2013 05:30 AM in reply to: martti.halminen
It did occur to me later that there could be a problem in that circumstance, so your suggestion not to use that as an argument name is certainly worthwhile.
Kent Cooper
mid-awe
Message 15 of 18 (183 Views)
01-21-2013 07:08 AM in reply to: pbejse
Thank you all for your help. Maybe this should not have been so difficult but it was. I really appreciate everyones help and now this is working exactly as I need it to. A great solution here saving me hundreds of lines of code. Again, thank you all. :smileyvery-happy:
mid-awe
Message 16 of 18 (176 Views)
01-21-2013 11:03 AM in reply to: pbejse
I have one more quick question.
I tried to use :
(foreach PLANT (vl-sort PLANTS '(lambda (x y) (< (car x) (car y))))
  (setq CATEGORY (vl-symbol-name PLANT))
  (foreach PLANTNAME (eval PLANT)
    (if	(>= (dict-get CATEGORY PLANTNAME) 1)
      (princ (strcat "\n\t "
		     PLANTNAME
		     (rtos (dict-get CATEGORY PLANTNAME) 2 0)
    (setq total (+ total (dict-get CATEGORY PLANTNAME)))
 To get the list alphabetized, but it didn't work. How can I do it correctly?
Thank you.
pbejse
Message 17 of 18 (164 Views)
01-21-2013 06:58 PM in reply to: mid-awe
Thank you.
Since  the plant lists are hard-coded, you can sort the lists PALM/TREE/SHRUBS then paste the sorted list in your code:
(acad_strlsort palm)
("Bismark" "Blue Fan" "Date" "Fan" "Pindo" "Pineapple" "Ponytail" "Pygmy" "Queen" "Sabal" "Sago" "Windmill")
(acad_strlsort shrub)
(acad_strlsort tree)
That way you dont have to sort the list everytime you use your routine
HTH
Cheers
mid-awe
Message 18 of 18 (137 Views)
01-22-2013 02:31 PM in reply to: pbejse
Thank you. I had a crazy idea about haveing the entire list sorted, but then I realized it makes little sense because they are categorized :smileylol:
You are not logged in.
Ask the Community
