• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Array within a boundary
    328 Views, 5 Replies
    03-20-2009 01:06 PM
    I'm looking to array blocks within a boundary. I'm not even sure how to approach or begin developing something along these lines.
    Thoughts:
    - perform a normal array, but select a boundary afterward which determines the limit for blocks that are kept; blocks with insertion points outside defined boundary are deleted.
    Logic is something like this:
    - select block
    - pick lower left [insertion] point
    - specify array parameters
    - select boundary
    - finish.
    Thanks for the help. -- KT
    Please use plain text.
    Distinguished Contributor
    Re: Array within a boundary
    03-20-2009 03:34 PM in reply to: KielT
    Do you have AutoCAD 2006 or higher? Sounds like it could be a dynamic block candidate. Would that work?
    03-20-2009 03:38 PM in reply to: KielT
    I'm using AutoCAD 2009 [and 2008 alternatively]. Using a dynamic block would work and would be great, how do you suggest I go about putting something like this together? -- KT
    03-20-2009 03:54 PM in reply to: KielT
    The best thing to do is look at an example that is close and try to suit it to your needs. Check AutoCAD's sample folder. Also talk to the folks on the forum here on Discussion Groups dedicated to Dynamic Blocks. And I ran across this helpful pdf with a google search. Check out page 6.
    http://www.cadmasters.com/class/ACAD2006DynamicBlocks2.pdf
    I've never done an array function myself.
    03-20-2009 04:00 PM in reply to: KielT
    Thanks for the information, but the problem still arises when the area to be populated is not rectangular. The problem is even worse when an arc is introduced into the boundary. -- KT
    *Some Buddy
    03-23-2009 07:20 AM in reply to: KielT
    Hi, here's my two cents:
    For non-rectangular areas, try to get the bounding
    box of the boundary. This would reduce the problem to only one situation to
    deal with. Further on, if you want to remove the instances that are physically
    outside the boundary (could have the insertion point inside though), then use
    your boundary as a crossing polygon and delete all the instances of the
    block that are outside your boundary (use ssget with a filter, in order to
    select all the instances of that block).
    If you want to remove all instances that have
    the insertion point outside the boundary (there could be instances that are
    inside the boundary), then you will have to use a function that checks if a
    point (in our case the insertion point) is inside a certain area and if not,
    remove that instance. Such a function was already published on this forum and it
    won't be hard to find and to implement.
    HTH
    Humans are born with a wide
    horizon.
    As time goes by, the horizon narrows and
    narrows, until it
    becomes a point of view.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
