Visual LISP, AutoLISP and General Customization
Area of multiple objects
3 REPLIES 3
sports7
508 Views, 3 Replies
Im looking for a Lisp that will give me the Area of multiple objects in SqFt.
3 REPLIES 3
Kent1Cooper
in reply to: sports7
Try a Search -- I'm pretty sure the same or very similar subject has come up before.  I know there are things to total the areas of multiple objects, and there must be things to report areas in square feet, though there may not be something with exactly what you're after, so it may take some combining.
Kent Cooper, AIA
daneson.marcelino
hello,
i created a routine which allows you to select a closed plines and alerts the total area of it.
hope it works on you.
have a good day 🙂
daneson.marcelino
;;;alert the total area of a close polylines in square meter and square feet
;;;created by daneson.marcelino upon request by blogger
(defun c:tarea ()
(setvar "INSUNITS" 6)
(setvar "CMDECHO" 0) ;setting drawing units into meters
(setq c_pline (ssget (list (cons 0 "LWPOLYLINE") (cons 70 1)))) ;sorting all closed polylines
(setq c_no (sslength c_pline)) ;number of sorted closed pline
(setq ct 0) ;setting counter
(setq m2f 10.7639) ;conversion of sqm to sqf
(setq areas (list))
(repeat c_no
(setq p_name (ssname c_pline ct))
(command "area" "o" p_name)
(setq p_area (getvar "area"))
(setq areas (append areas (list p_area)))
(setq ct (+ ct 1))
(setq total_area_sqm (apply '+ areas))
(setq total_area_sqf (* total_area_sqm m2f))
(alert (strcat (strcat "area in sqm=" (rtos total_area_sqm)) "\n" (strcat "area in sqf=" (rtos total_area_sqf))))
(setvar "CMDECHO" 1)
(progn (princ))
(textscr)
(princ "created by: daneson.marcelino@gmail.com")
(princ)
);;end of function
”Boost
