• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual LISP, AutoLISP and General Customization
    Distinguished Contributor lai
    lai
    Accepted Solution
    Arc text exploding problem
    520 Views, 8 Replies
    08-16-2011 10:47 PM
    I have encounter some text exploding problem. As shown in attachment, I would like to know if there any possible way I can explode the text into polyline or single line and maintain it within the position and style?
    Please use plain text.
    *Expert Elite*
    Re: Arc text exploding problem
    08-17-2011 05:12 AM in reply to: lai
    Just use the explode command to explode the mirrored arc text.  It worked with AutoCAD 2010.  See attached.
    lai
    08-17-2011 10:27 PM in reply to: azrdgldr
    Hi, what i require is the text can be direct explode without changes its orientation. If i use the normal explode, i will sort of reverse direction.Any idea to do it or type a mirror arc text directly?
    *Expert Elite*
    08-17-2011 10:54 PM in reply to: lai
    A crude way of achieving that is  plot thru DXB
    lai
    08-17-2011 11:02 PM in reply to: pbejse
    Wow, that's the end result i need. Mind i ask what do you mean by plot with DBX? Can give a little more details. Thanks.
    *Expert Elite*
    08-17-2011 11:18 PM in reply to: lai
    First add the DXB plot
    Options
    Plot and Publish
    Add or Configure Plotters
    Add-A-Plotter Wizard
    Next
    Next
    Autocad DXB File
    When you plot you will DXB file.pc3 or whatever you named it
    Try it out to have a feel for it
    To insert the DXB format
    DXBIN
    lai
    08-17-2011 11:41 PM in reply to: pbejse
    ok,just now give it a try and it's good.By the way, not sure if i have done wrongly or not, cause when i insert the dbx file, the explode text is not in scale 1:1, though when plotting time, i make it to be plot in scale 1:1.is it i need to rescale it back to original size everytime? Please advise.
    Additonally, is there way we can direct type a mirror text as shown in my previous attachment.? Previously i use to block the text and mirror the block.
    *Expert Elite*
    08-17-2011 11:55 PM in reply to: lai
    I guess you could plot to scale, didnt really gave it much thought
    as for a newly created ARCTEXT you can use a Text Style with backwards option, that might work
    EDIT:
    I tried 1:1 on your drawing, it works fine, I used ISO A0, no need to scale down/up, make sure you uncheck FIT TO SCALE
    lai
    08-23-2011 12:55 AM in reply to: pbejse
    Hi i have try again the dxb plotting again...I still somehow when i use the DXBIN command to insert the DXB file, it still not in scale 1:1..I have attach along the pdf to show my setting during plot out. Then i notice that when i input time, it won't ask me to pick a insert point also.
