Visual LISP, AutoLISP and General Customization
*Rich Banker
Message 1 of 9 (80 Views)
Arc Length
80 Views, 8 Replies
05-04-2005 02:44 PM
Does anyone have a lisp routine that will label the length of an arc and
place the annotation to read L=length' along the arc?
I'm using Autocad 2004.
Thanks for any help you can give!
Rich
*R.K. McSwain
Message 2 of 9 (80 Views)
Re: Arc Length
05-04-2005 03:58 PM in reply to: *Rich Banker
"Rich Banker" wrote in message news:4835194@discussion.autodesk.com...
Yes, but I'm not at liberty to distribute it.
While you are waiting, Check out DIMARC.LSP at http://www.turvill.com/t2/free_stuff/index.htm
It's not exactly what you are asking for, but it may do if you cannot find just the right routine.
*tcebob
Message 3 of 9 (80 Views)
Re: Arc Length
05-04-2005 04:47 PM in reply to: *Rich Banker
Try this:
(defun c:darc( / osm ar arc rad pt1 pt2) ; Dim. Arc (for "R25'")
(setvar "peditaccept" 1)
(setq osm (getvar "osmode"))
(setvar "osmode" 512) ;near
(while
(setq ar(entsel "\nSelect an arc where you want to place the text: "))
(setq arc (entget (car ar)))
(if(member(cdr(assoc 0 arc))'("CIRCLE" "ARC"))
(progn
(setq rad (cdr(assoc 40 arc)))
(setq pt1 (cadr ar))
(setq pt2 (getpoint "\nPick a direction (NEAR)" ))
(if (= (cdr (assoc 40 (tblsearch "style" (getvar "textstyle")))) 0)
(command "text" "J" "bl" pt1 "" pt2 (strcat "R" (rtos rad 2 2)))
(command "text" "J" "bl" pt1 pt2 (strcat "R" (rtos rad 2 2)))
) ;progn
(princ "\nNot a CIRCLE or ARC")
) ;if
) ;while
(setvar "osmode" osm)
You can alter it to read L= . . .
rs
Rich
*Rich Banker
Message 4 of 9 (80 Views)
Re: Arc Length
05-05-2005 06:03 AM in reply to: *Rich Banker
When I try to run it, I get the error message "error: malformed list on
input"
What does that mean, and is it possible to fix?
Thanks for your help, I really appreciate it!
Rich
"tcebob" wrote in message
news:4835343@discussion.autodesk.com...
Try this:
(while
(progn
) ;progn
) ;if
) ;while
rs
Rich
*Rich Banker
Message 5 of 9 (80 Views)
Re: Arc Length
05-05-2005 06:06 AM in reply to: *Rich Banker
Thanks for your time and the link, but that's not quite what I'm looking
for.
Rich
"R.K. McSwain" wrote in message
news:4835285@discussion.autodesk.com...
*tcebob
Message 6 of 9 (80 Views)
Re: Arc Length
05-05-2005 08:22 AM in reply to: *Rich Banker
Try this. Maybe some lines got folded in the transmission.
rs
news:4835660@discussion.autodesk.com...
input"
Rich
Try this:
(while
(progn
) ;progn
) ;if
) ;while
rs
Rich
*Rich Banker
Message 7 of 9 (80 Views)
Re: Arc Length
05-05-2005 11:27 AM in reply to: *Rich Banker
That works, but I needed it to label the length of the arc, not the radius.
Is it posible to modify that routine to do that.
I have little LISP programming experience...
Thanks for your help!
Rich
news:4835906@discussion.autodesk.com...
rs
input"
Rich
Try this:
or "R25'")
(while
(progn
) ;progn
) ;if
) ;while
rs
Thanks for a
Rich
*Tim Decker
Message 8 of 9 (80 Views)
Re: Arc Length
05-06-2005 06:14 AM in reply to: *Rich Banker
I wrote this long ago, in an autocad far far away.
(defun c:dimlen (/ obj deg len)
(setq obj (entsel "\nSelect Arc: "))
(setq deg (* 180.0 (/ (- (cdr (assoc 51 (entget (car obj)))) (cdr (assoc 50
(entget (car obj))))) pi)))
(setq len (/ (* 2 pi (cdr (assoc 40 (entget (car obj)))) deg) 360))
(command ".dimangular" obj "t" (rtos len (getvar "dimunit") (getvar
"dimdec")) pause)
(princ)
Rich
*Rich Banker
Message 9 of 9 (80 Views)
Re: Arc Length
05-06-2005 06:26 AM in reply to: *Rich Banker
Thanks Tim, I appreciate your help!
Rich
"Tim Decker" wrote in message
news:4837048@discussion.autodesk.com...
"dimdec")) pause)
(princ)
Rich
You are not logged in.
Announcements
Need installation help?
Ask the Community
