I'm trying to get familiar with AutoCAD. Google and didn't manage to solve a problem :
In AutoCAD LT 2013, I created a custom command called Special fillet :
I created two aliases at the end of acadlt.pgp :
SF, *SFILLET
C, *COPY
When i type C, it works fine (just a test) but although it appears correctly in the Command prompt, SF doesn't work and it keeps telling me : UNKNOWN COMMAND "SF"
Last thing, if I create an icon in a toolbar with the special fillet command : it works fine... Very disturbing.
Any idea or advice?
Thanks.
@gruzlor wrote:.... I created a custom command called Special fillet :
Macro : ^C^C_fillet;p;r;0.1
.... if I create an icon in a toolbar with the special fillet command : it works fine... Very disturbing.
Does the icon in the toolbar work if the current Fillet radius isn't already 0.1? I think you have your command options in the wrong order. Try:
^C^C_fillet;r;0.1;p
Thanks Kent for your answer.
Both solution work fine in the toolbar but none of them work as an alias (UNKNOWN COMMAND). I tried to restart AutoCAD, to reload acadlt.pgp.
Still searching...
Hi
another way is:
save this code in a text file and rename text file to "SF.LSP" then move this file to autocad SUPPORT folder.
(Defun C:SF() (COMMAND "FILLET" "R" "0.1" "FILLET") )
Now look for acaddoc.lsp, if you did not find this file then make it via Notepad and save it in SUPPORT folder.
Please add this line in acaddoc.lsp:
(LOAD "SF")
(close AutoCAD and run it again)
It's done! just type: SF and select two line to fillet!
hope to help you
Hi aqdam1978,
Thanks. I tried but it also didn't work. Unless I'm wrong LISP is not supported with LT version of AutoCAD. Right?
@gruzlor wrote:Thanks Kent for your answer.
Both solution work fine in the toolbar but none of them work as an alias (UNKNOWN COMMAND). ....
I don't have LT, and don't know enough about defining commands there, and I don't find anything explicit about this in AutoCAD Help, but: Could it be that aliases can be used only to invoke native AutoCAD [whether LT or full] commands? If so, I don't know what you could do about it.
YES, you are right,
My solution works fine with AutoCAD full version.
AutoCAD LT has not LISP capability.
I never had LT version, So I dont know how can customize your own commands.
In LT version you can just customize CUI only and you dont have access to:
1-AutoLISP
2-ObjectARX
3-Action Recorders
so, you can customize just AutoCAD native commands in CUI.
as I told you, I'm not familiar with LT version, so I can't help you! 😞
Yep... you're probably right and this thread seems to confirm your point.
I guess I will search a bit more and probably go for a keyboard shortcut.
Thanks again for the help.
