Add scales to list
6 REPLIES 6
jjorovi
494 Views, 6 Replies
Add scales to list
Help please!
I need to modify the code below.
When I run the command and write the scale, I need to change the name of the scale and the ratio automatically.
The ratio should always be in the format "1: #", also the name of the scale.
Maybe assigning more varibales with "setq", I do not know.
Any suggestions?
(defun c:test ()
(setvar "cmdecho" 0)
(setq name (getint "\nType the scale you need:"))
(setq ratio (strcat "1:" "0.1"))
(command "-SCALELISTEDIT" "Add" name ratio "Exit")
(setvar "cmdecho" 1)
(princ)
6 REPLIES 6
Ajilal.Vijayan
in reply to: jjorovi
Like this ?
(defun c:test ()
(setq ratio (strcat "1:" (itoa name)))
(command "-SCALELISTEDIT" "Add" ratio ratio "Exit")
(princ)
jjorovi
in reply to: Ajilal.Vijayan
It works well, but my work units are in meters.
For example, if I write the scale of 1:100, the ratio should be 1:0.1 (name/1000)
I can not find the correct function to do this.
Thanks for responding.
hmsilva
maybe something like this
(defun c:test ( / name)
(setq name (getint "\nType the scale you need >>> 1:"))
  (if name
    (progn
      (command "-SCALELISTEDIT" "Add" (strcat "1:"(itoa name)) (strcat "1:" (rtos (/ name 1000.))) "Exit")
      );; progn
    );; if
(princ)
 HTH
Henrique
jjorovi
in reply to: hmsilva
Excellent. Two days trying to make the lisp. Still much to learn.
At the end I included the variable CANNOSCALE to set the new scale.
Thank you very much
  (if name
    (progn
      );; progn
    );; if
(setvar "CANNOSCALE" (strcat "1:"(itoa name)))
(princ)
hmsilva
You're welcome, jjorovi
Glad I could help
Henrique
hmsilva
setting the CANNOSCALE outside from the if, may generate an error if name is nil
this way will be better
  (if name
    (progn
      );; progn
    );; if
(princ)
 Henrique
”Boost
