The following snippet works in 2012 but fails in 2013 and 2014
(if layer
(progn
(setq lays (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
(if (vl-catch-all-error-p
(setq objlay (vl-catch-all-apply 'vla-item (list lays layer)))
(setq objlay (vla-add lays layer))
(setq objlay (vla-get-activelayer (vla-get-activedocument (vlax-get-acad-object))))
This line ...
Returns:
error: ActiveX Server returned an error: Library not registered
Anyone have an idea what's wrong?
Works for me in 2013 sp1:
Comando: (setq lays (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
#<VLA-OBJECT IAcadLayers 0000000028533888>
Comando: (setq objlay (vla-add lays "NEWLAYER"))
#<VLA-OBJECT IAcadLayer 0000000028534de8>
Thanks. I had uninstalled AutoDesk 360 and something happened. I reinstalled AutoCad 2014 and now everything is working. Thanks for your input.
Don Butler
