Visual LISP, AutoLISP and General Customization
ActiveX Selection Sets
5 REPLIES 5
gdaniels2
921 Views, 5 Replies
Has anyone tried retrieving an ActiveX selection set in AutoCAD 2013 (AutoCAD Architecture 64bit on Windows 7 is what I am using)?
Using a piece of LISP I got from the ADN developer site, it no longer works and gives this error....
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
(defun c:erset (/ acApp acDoc selSets ss1)
   (vl-load-com)
   (setq acApp (vlax-get-acad-object))
   (setq acDoc (vla-get-activeDocument acApp))
   (setq selSets (vla-get-SelectionSets acDoc))
   (setq ss1 (vla-item selSets "TEST1"))
   (princ "Number of items in selection set TEST1 = ")
   (princ (vla-get-count ss1))
   (if (> (vla-get-count ss1) 0)
      (progn
         (alert "Erasing objects in selection set TEST1")
         (vla-erase ss1)
      ) ;progn
   ) ;if
   (princ)
) ;defun
Same with a similar one I found via google and have been using it for years. Unfortunatley my lisp is very basic so I have little idea if it an be fixed!
(defun c:getSset()
(vl-load-com)
(setq ss-vba (vla-item
(vla-get-selectionsets
(vla-get-activedocument
(vlax-get-acad-object)))
"SSforLisp"));; gets the ActiveX SS
(setq ss-lisp (ssadd));;creates a new ename-based ss
(vlax-for ent ss-vba
(ssadd (vlax-vla-object->ename ent) ss-lisp)
);;add each object's ename to the ename-ss
What about creating an AutoLisp selection set from .NET - is it possible, if so I would prefer to do that instead?
The goal is to create some objects in .NET (using activeX or managed code) and then have some way to access these objects via the command line I'm assuming they only way is using an AutoLISP selection set.
Many thanks,
Graham
MiTek Industries
5 REPLIES 5
gdaniels2
in reply to: gdaniels2
UPDATE...
I found a sample to transfer a selection set into lisp (using a VB.NET lisp function). Not tested it out yet but it looks promising, I think I need to transfer my activex objects into managed ones and then build a selection set and result buffer?
        <LispFunction("MyLispFunction2")> _
            Public Function VBNetFunction4(ByVal myLispArgs As ResultBuffer) As ResultBuffer
            Dim rbfResult As ResultBuffer
            Dim ed As Autodesk.AutoCAD.EditorInput.Editor
            ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
            Dim prmptSelOpts As New PromptSelectionOptions()
            Dim prmptSelRes As PromptSelectionResult
            prmptSelRes = ed.GetSelection(prmptSelOpts)
            If prmptSelRes.Status <> PromptStatus.OK Then
                rbfResult = New ResultBuffer(New TypedValue(5019))
                Return rbfResult
            Dim selSet As SelectionSet
            selSet = prmptSelRes.Value
            rbfResult = New ResultBuffer( _
                        New TypedValue(CInt(5007), selSet))
            Return rbfResult
        End Function
gdaniels2
Arrrghh!
Just tested it and it gives the same error message as the other examples!!!
Hallex
Worked on my end with small changes:
            prmptSelOpts.MessageForRemoval = vbLf + "Nothing selected"
            prmptSelOpts.MessageForAdding = vbLf + "Select some objects:"
                Return rbfResult
            ed.SetImpliedSelection(selSet)
                        New TypedValue(CInt(5007), ed.SelectImplied.Value))
            Return rbfResult
        End Function
 In the command line I've typed
(setq sset (MyLispFunction2))
Another way with using pickfirstselectionset,
see what this function will retain for you:
        '   (selected objects)
        <LispFunction("ListSelected")> _
        Public Shared Function ListSelected(resBufIn As ResultBuffer) As ResultBuffer
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim blkId As ObjectId = db.BlockTableId
            Dim resBufOut As New ResultBuffer()
            If ed.SelectImplied.Value.Count = 0 Then
                ed.WriteMessage(vbLf + "Works with previously selected objects only!")
                resBufOut.Add(New TypedValue(CInt(LispDataType.Nil)))
            Else
                Using tr As Transaction = db.TransactionManager.StartOpenCloseTransaction()
                    Dim bt As BlockTable = TryCast(tr.GetObject(blkId, OpenMode.ForRead), BlockTable)
                    resBufOut.Add(New TypedValue(CInt(LispDataType.ListBegin)))
                    Dim sset As SelectionSet = ed.SelectImplied.Value
                    For Each sobj As SelectedObject In sset
                        resBufOut.Add(New TypedValue(CInt(LispDataType.ObjectId), sobj.ObjectId))
                    Next
                    resBufOut.Add(New TypedValue(CInt(LispDataType.ListEnd)))
                End Using
            Return resBufOut
        End Function
        '' usage : (setq entlist (ListSelected))
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
gdaniels2
in reply to: Hallex
Worked like a charm thanks!
Hallex
Glad to hear that,
Kind regards,
Cheers 🙂
”Boost
