Visual LISP, AutoLISP and General Customization
Active Paperspace Viewport Again!
10 REPLIES 10
Message 1 of 11
328 Views, 10 Replies
I posted before about this item but problem
happened.
As some of guys suggested, I set viewport ID to
systemvariable ("cvport") but Autocad crashed by following routine.
This code worked when I run the layout for the
first time but When I switched model space,back to layout again ,and then run
this code,
Acad crashed.
  Any suggestion will be
appreciated.
size=2>
thanks,
size=2>
Michi
(defun C:AdjustPVport ( / )
  ;find display object
  (setq SS
(ssget "X" '( (-4 . "<AND") (0 . "VIEWPORT") (8 . "VPORT") (-3 ("Lug-Plate"))
(-4 . "<NOT") (69 . 1) (-4 . "NOT>") (-4 . "AND>") )))
(command "mspace")
  (setq INDEX 0)
  (repeat
(sslength ss)
    (setq ENAME (ssname SS
INDEX))
    (setq ELIST (entget ENAME
'("Lug-Plate")))
    (setq VportID (cdr (assoc 69
ELIST)))
    (setvar "cvport" VportID)
(setq LugName  (CDR (NTH 1 (CDADR (ASSOC -3 ELIST))))
    (setq VPscale  (CDR (NTH 2 (CDADR (ASSOC -3
ELIST)))) )
    (setq CenterX  (CDR (NTH 3 (CDADR (ASSOC
-3 ELIST)))) )
    (setq CenterY  (CDR (NTH 4 (CDADR
(ASSOC -3 ELIST)))) )
    (setq CenterP (list CenterX
CenterY))
    ;activate and adjust scale
(command "mspace")
    (command "ucs" "r"
lugname)
    (command "plan" "c")
(command "zoom" "scale" (strcat (rtos (/ 1 VPscale) 2 10)
"XP"))
    (command "zoom" "c" CenterP
    (setq INDEX (1+ INDEX))
  (command
"pspace")
  (princ)
10 REPLIES 10
Message 2 of 11
I did not look real hard at this code, but what if
no viewports are found?  ss = nil.
You should do
(if (setq ss .....................)
  (progn
     (command
".mspace")
     (setq INDEX 0)
   );closes progn
);closes if
-Jason
face=Arial size=2>
happened.
routine.
this code,
Acad crashed.
appreciated.
size=2>
thanks,
size=2>
Michi
  (setq SS
("Lug-Plate")) (-4 . "<NOT") (69 . 1) (-4 . "NOT>") (-4 . "AND>")
  (command "mspace")
  (setq INDEX 0)
  (repeat  (sslength ss)
INDEX))
'("Lug-Plate")))
ELIST)))
ELIST)))) )
(CDADR (ASSOC -3 ELIST)))) )
CenterY))
scale
    (command "mspace")
    (command
"ucs" "r" lugname)
    (command "plan"
"c")
2 10) "XP"))
(command "pspace")
  (princ)
Message 3 of 11
Also Don't forget to localize your
varaibles.
-Jason
happened.
routine.
this code,
Acad crashed.
appreciated.
size=2>
thanks,
size=2>
Michi
  (setq SS
  (command "mspace")
  (setq INDEX 0)
INDEX))
'("Lug-Plate")))
ELIST)))
ELIST)))) )
CenterY))
scale
    (command "mspace")
    (command
"ucs" "r" lugname)
    (command "plan"
"c")
2 10) "XP"))
(command "pspace")
  (princ)
Message 4 of 11
You'd better thrown in some detection and selection filtering for the
current layout...
(setq ctab (getvar "ctab"))
(if (= ctab "Model")
(prompt "\nPlease switch to a paper space layout.")
(if (setq SS (ssget "X" (list '(-4 . " "VPORT")(cons 410 ctab) '(-3 ("Lug-Plate")) '(-4 . " "NOT>") '(-4 . "AND>"))))
(progn
; etc.
John Uhden, Cadlantic/formerly CADvantage
--> mailto:juhden@cadlantic.com
--> http://www.cadlantic.com
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
FAX 732-528-1332
"michi" wrote in message
news:FAFAA35CD8A6DEF6C98193C9B3514876@in.WebX.maYIadrTaRb...
> I posted before about this item but problem happened.
> As some of guys suggested, I set viewport ID to systemvariable ("cvport")
> This code worked when I run the layout for the first time but When I
switched model space,back to layout again ,and then run this code,
> Acad crashed.
> Error Messages is "INTERNAL ERROR:!Scandr.cpp@1117.eLockViolation"
> Any suggestion will be appreciated.
thanks,
Michi
> (setq SS (ssget "X" '( (-4 . " ("Lug-Plate")) (-4 . "") (-4 . "AND>") )))
> (command "mspace")
> (setq INDEX 0)
> (setq ENAME (ssname SS INDEX))
> (setq ELIST (entget ENAME '("Lug-Plate")))
> (setq VportID (cdr (assoc 69 ELIST)))
> (setq LugName (CDR (NTH 1 (CDADR (ASSOC -3 ELIST)))) )
> (setq VPscale (CDR (NTH 2 (CDADR (ASSOC -3 ELIST)))) )
> (setq CenterX (CDR (NTH 3 (CDADR (ASSOC -3 ELIST)))) )
> (setq CenterY (CDR (NTH 4 (CDADR (ASSOC -3 ELIST)))) )
> (setq CenterP (list CenterX CenterY))
> (command "mspace")
> (command "ucs" "r" lugname)
> (command "zoom" "scale" (strcat (rtos (/ 1 VPscale) 2 10) "XP"))
> (command "zoom" "c" CenterP "")
> (command "pspace")
> (princ)
Message 5 of 11
Why not just......
(if (= "Model" (getvar "ctab"))
(setvar "tilemode" 0)
etc.....
John Uhden wrote in message
news:7201492989B90EE54CA076068273917F@in.WebX.maYIadrTaRb...
> current layout...
> (if (setq SS (ssget "X" (list '(-4 . " > "VPORT")(cons 410 ctab) '(-3 ("Lug-Plate")) '(-4 . " > "NOT>") '(-4 . "AND>"))))
> (progn
> ; etc.
> 2 Village Road
> Sea Girt, NJ 08750
> Tel. 732-974-1711
> FAX 732-528-1332
("cvport")
> > Acad crashed.
> thanks,
> Michi
> > (setq SS (ssget "X" '( (-4 . " (-3
> > (command "mspace")
> > (setq INDEX 0)
> > (command "mspace")
> > (command "pspace")
> > (princ)
Message 6 of 11
For that matter, do we know this is A2K+?
(if (= 1 (getvar "tilemode"))
-Jason
Jason Piercey wrote in message
news:E69AE34D8A7D176C5FE1833C9ED4964B@in.WebX.maYIadrTaRb...
> Why not just......
> etc.....
> > current layout...
> > (if (setq SS (ssget "X" (list '(-4 . " > > "VPORT")(cons 410 ctab) '(-3 ("Lug-Plate")) '(-4 . " .
> > (progn
> > ; etc.
> > 2 Village Road
> > Sea Girt, NJ 08750
> > Tel. 732-974-1711
> > FAX 732-528-1332
> ("cvport")
> > > Acad crashed.
> > thanks,
> > Michi
> > > (setq SS (ssget "X" '( (-4 . " > (-3
> > > (command "mspace")
> > > (setq INDEX 0)
> > > (command "mspace")
> > > (command "pspace")
> > > (princ)
Message 7 of 11
I dunno, maybe he doesn't want to regen.
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
FAX 732-528-1332
"Jason Piercey" wrote in message
> Why not just......
> etc.....
> > current layout...
> > (progn
> > ; etc.
> > 2 Village Road
> > Sea Girt, NJ 08750
> > Tel. 732-974-1711
> > FAX 732-528-1332
> ("cvport")
> > > Acad crashed.
> > thanks,
> > Michi
> > > (command "mspace")
> > > (setq INDEX 0)
> > > (command "mspace")
> > > (command "pspace")
> > > (princ)
Message 8 of 11
I was just going by his words "When I switched model space,back to layout
again ..."
2 Village Road
Sea Girt, NJ 08750
Tel. 732-974-1711
FAX 732-528-1332
news:AA1CD30E4C288AB025C0E5324B2325BF@in.WebX.maYIadrTaRb...
> -Jason
> > Why not just......
> > etc.....
> > > current layout...
> > > (if (setq SS (ssget "X" (list '(-4 . " .
> > > "VPORT")(cons 410 ctab) '(-3 ("Lug-Plate")) '(-4 . " '(-4
> > > (progn
> > > ; etc.
> > > 2 Village Road
> > > Sea Girt, NJ 08750
> > > Tel. 732-974-1711
> > > FAX 732-528-1332
> > ("cvport")
> > > > Acad crashed.
> > > thanks,
> > > Michi
> > > > (setq SS (ssget "X" '( (-4 . " "VPORT")
> > (-3
> > > > (command "mspace")
> > > > (setq INDEX 0)
> > > > (command "mspace")
> > > > (command "pspace")
> > > > (princ)
Message 9 of 11
Thank you for your help. I am using A2K.
I found one solution.
When regenall command is manually executed and then run the routine, it
works.
(Interactively like adding (command "regenall") in front of the routine,
again it crashed.)
I don't know the reason but any way I found temporary cure.
thanks,
Michi
news:2373885FEDCDF20E0A2225AEB4EF58AF@in.WebX.maYIadrTaRb...
> 2 Village Road
> Sea Girt, NJ 08750
> Tel. 732-974-1711
> FAX 732-528-1332
> > Why not just......
> > etc.....
> > > current layout...
> > > (progn
> > > ; etc.
> > > 2 Village Road
> > > Sea Girt, NJ 08750
> > > Tel. 732-974-1711
> > > FAX 732-528-1332
> > ("cvport")
> > > > Acad crashed.
> > > thanks,
> > > Michi
> > (-3
> > > > (command "mspace")
> > > > (setq INDEX 0)
> > > > (command "mspace")
> > > > (command "pspace")
> > > > (princ)
Message 10 of 11
Michi-
Do a search for "elock violation" within this group. There are some threads
that will give you info-
Look for a thread on this NG titled "Elock Violation Advice". It's from
around the middle of February, and one titled "Combining an application with
reactors and calling another without them" from the 17th of April.
Good Luck
Joe
Message 11 of 11
Thank you for information, Joe!
Michi
Joseph Charpentier wrote in message
news:9B6FE89DD875F9B2499C208714465723@in.WebX.maYIadrTaRb...
> Michi-
threads
with
> Good Luck
> Joe
”Boost
