Visual LISP, AutoLISP and General Customization
balisteor
Message 1 of 15 (215 Views)
Accessing & Editing Rollover tips.
215 Views, 14 Replies
12-17-2009 08:56 AM
I would like to know if anyone has been able to add information to rollover tips. I would like to send some strings to display along with the typical information that you see when you roll over a block object. Oh and don't forget the part where I want to do it with Lisp. :smileyvery-happy:
Ideas or similar accomplishments would be greatly appreciated.
Thanks.
*Some Buddy
Message 2 of 15 (215 Views)
Re: Accessing & Editing Rollover tips.
12-17-2009 09:45 AM in reply to: balisteor
AFAIK those tips are not exposed in ActiveX API. I'm afraid that the only
way to do it, is using the .NET API or ARX.
HTH
Humans are born with a wide horizon.
As time goes by, the horizon narrows and
narrows, until it becomes a point of view.
a écrit dans le message de news:
6306486@discussion.autodesk.com...
Thanks.
balisteor
Message 3 of 15 (215 Views)
12-17-2009 09:59 AM in reply to: balisteor
I knew it. : (
Thank you sir.
*Some Buddy
Message 4 of 15 (215 Views)
12-17-2009 10:07 AM in reply to: balisteor
You're welcome.
6306554@discussion.autodesk.com...
I knew it. : (
Thank you sir.
*Expert Elite*
dgorsman
Message 5 of 15 (215 Views)
12-17-2009 10:28 AM in reply to: balisteor
I think you *might* be able to do it within a (grread...) loop, using temporary MTEXT to display the information. Look for "Dynamic Leader" for examples.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
*Some Buddy
Message 6 of 15 (215 Views)
12-17-2009 10:34 AM in reply to: balisteor
I think that the OP wants to edit the existing tips, adding some extra info
to the existing one, not to create his own tips.
6306571@discussion.autodesk.com...
examples.
balisteor
Message 7 of 15 (215 Views)
12-17-2009 10:38 AM in reply to: balisteor
That is true that I would much rather add to the rollover tips they are much easier to read and look pretty :smileyvery-happy:
But I am open to any and all ideas.
balisteor
Message 8 of 15 (215 Views)
12-17-2009 10:41 AM in reply to: balisteor
Dynamic Leader? I'm not finding anything.
*Some Buddy
Message 9 of 15 (215 Views)
12-17-2009 10:43 AM in reply to: balisteor
Then go for it :smileyhappy:
6306577@discussion.autodesk.com...
*Some Buddy
Message 10 of 15 (215 Views)
12-17-2009 10:46 AM in reply to: balisteor
But unfortunately you won't be able to hover and to make it pop. Most
probably, if you will be able to create it using (grread..) and stuff, you
will have to select an entity in order to make it pop.
You are not logged in.
Announcements
Need installation help?
Ask the Community
