OK. Some problems.
In R14 where there is a parent dimension style named ARCH, and a child
leader style under ARCH:
(setq info (tblsearch "arch$7")) ;returns overrides for leader style.
(setq tstylinfo (tblsearch "style" (cdr(assoc 340 info))));returns the
text style for the child style.
That is fine and can be used easily to get a child dimension text style.
In AC2K, even though there though dimstyle ARCH$7 exists, it is evident
from looking at the table entries for "ARCH" and "ARCH$7" that they point to
the same text style entity name, even though the leader text style has been
set to a different text style. (Seems like the change between versions is a
step backwards).
The strange thing is that if DXFOUT is performed, the DIMSTYLE table entries
for ARCH and ARCH$7 in the DXF file point to different text style handles.
Since I don't want to have to write a DXF file and parse the results to
simply create notes in the current leader text style, I need some more
ideas. Thanks again.
"Jason Piercey" wrote in message
news:3B30AAF4.7DC5C7B4@atreng.com...
> The name of the child style? (strcat "parentstyle name" "$7")
> -Jason
