Visual LISP, AutoLISP and General Customization
Acad13... nothing works
4 REPLIES 4
umlauf2
297 Views, 4 Replies
Hy, had to work on a acad2013 pc... nothing worked
(setq q 3)
no reponse
!q
no response
(type q)
no response
i really hope it is just a system variable in acad 13 which causes this problem
any help welcome
4 REPLIES 4
hmsilva
in reply to: umlauf2
umlauf2
try to change the System variable CLIPROMPTUPDATE to 1
Hope that helps
Henrique
dbroad
Could the results have scrolled off the command line?  IOW, is your command line set to a single line high?  If so, hit F2 to see the results.  If no results, try reinstalling or repairing.  I've never heard of that behavior.
Architect, Registered NC, VA, SC, & GA.
braudpat
in reply to: dbroad
Hello
You could have a Virus coming from an ACAD.LSP file which is besides yours DWGs ...
Have you many "ACAD.lsp" files anywhere ?
Bye, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
umlauf2
thank you for your suggestions.
Today it worked without any problem...
But i still do miss the "BURST" command.
”Boost
