Visual LISP, AutoLISP and General Customization
AcDbZombieEntity -- What is it?
6 REPLIES 6
1187 Views, 6 Replies
What the heck is a AcDbZombieEntity?
Can't find any reference in the help files.
6 REPLIES 6
EC-CAD
You don't want to know.
[Or, if he tells you, he'll have to kill you....]
wrote...
EC-CAD
Ok,
Search for Zombie..has a few tokens, including this one:
Im looking for an (V)Lisp way to delete Proxies which are not
defined as an Block - e.g. rtext. (AcDbZombieEntity)
Is there a way, without using SPurge, or without loading rtext.arx?
How ist there a general way to delete this kind of proxys?
I knew Killproxy.lsp but therevor bust be an Proxy be an Member of the Block Table.
I'll hope for Your help
Greetings
CADwiesel
Bob
Does this help?
http://tinyurl.com/75not
Autodesk Discussion Group Facilitator
"Kevin Nehls" wrote in message
news:4865139@discussion.autodesk.com...
Jason Piercey wrote:
> Does this help?
Ah, thanks. RTEXT it is. Wonder why it wasn't autoloading the
rtext.arx when I opened those drawings. I have no problem with other
drawings. Oh well. It is something I could probably just load globally
anyway and forget about it.
akubeda
I use Acad 2006 and Acad 2009.
May it came from Autocad 2007 or newer that has tecnique to save a solid objects. I suggest you explode it first, make any changes, an convert it back to block with same name and insertion point. Good luck Smiley Happy
”Boost
