Change the 4 in each (angtos) function to 1 to get degrees/minutes/seconds instead of surveyor's units. Set ANGBASE to 270 and ANGDIR to 1 to have it read from South as 0 degrees and figure angles clockwise. However, I haven't tested the combination of those settings with that routine -- you may need to make some compensation, because some Lisp functions may return angles in default directions, ignoring ANGBASE and/or ANGDIR settings, just as some return points in World Coordinates, ignoring the current Coordinate System.
Kent Cooper
leksboy wrote...
i want ANGLE only without direction ( N,E,S,W) starting from SOUTH as zero angle
Kent Cooper, AIA
