ATTOUT to include more properties
1 REPLY 1
JCprog
430 Views, 1 Reply
I found this code from one of the forums and it works nicely, I just need it to inlcude more properties from the dynamic block such as the "Name", x,y,z  & "Visibility" state. (The bnames are to extract data from those blocks only). Please help Smiley Happy Thank in advance!
(defun c:out-att ()
(load "attout")
(setq fna "C:\\att.txt")
	(setq data   nil
	      bnames "blk01,blk02,blk03,`*J*"
	      ss     (ssget "_X"
			    (list '(0 . "INSERT") '(66 . 1) (cons 2 bnames))
(bns_attout fna ss)
 The code is partnered with ATTIN as I need the data be extracted and imported back into the blocks.
(defun  c:in-att (/ tmpn)
  (load "attout")
  (setq #bns_attin_modified 0)
  (if (setq
        tmpn
         (findfile
           "C:\\att.txt"
    (bns_attin tmpn nil)
1 REPLY 1
braudpat
in reply to: JCprog
Hello from France
I am not at all a developper but I have posted in the past updated (Support of Dynamic Blocks) routines for ATTIN / ATTOUT coming from a French Developper (from Brice/Bryce - already posted on a French Cad Foum - cadxp.com) ... Maybe it could help you !?
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/ATTIN-ATTOUT-with-dynamic-blocks/m-p/...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
”Boost
