I’m new to using ActiveX and the vlisp editor. I played with entering a SLOT lisp using a tutorial from afralisp.com.
Everything seemed to be working fine till I went to the next step the tutorial. After closing out all windows in the vlisp editor, then reopening it, In Visual LISP Console of the editor I entered (vl-load-com). I then entered (setq acadObject (vlax-get-acad-object)). I then highlighted ACADOBJECT from the previous line and selected “add watch”. As soon as I did that AutoCAD issues the command Slot, which is the lisp I was messing with (now) yesterday. It’s as if that lisp is saved somewhere I know I did not save it anywhere. Any suggestions as to what is going on? I’m using Acad 2014.
Solved by David125. Go to Solution.
If you use vlisp-compile to compile the lisp file, the fas file may be saved to somewhere within the autocad search path.
If you remember the SLOT lisp file name try typing something like this at the command line.
(findfile "SLOT.fas")
To find it, use the windows explorer Find tool:
slot.lsp or slot.fas , or slot*.lsp etc.
To not lose the messing around files,
make spare copies like of the original,
in a seporate folder for such things.ings.
Thanks for the suggestion. I did try, to no avail, the searches you recomended. I ended up having to delete the vlide.dsk file from the acad support directory. I had inadvertantly entered some commands that kept vlide running in a loop. I don't quite understand it myself except that now everything seems to ve working find now.
General well-being and peace-of-mind practices for any modern and publically available computers are to NOT mess with any of the files that constitute a program WHILE THAT PROGRAM IS RUNNING. Background included (you can check this by pulling up the task manager and scanning visually the list of applications that are running for an item that looks similar to the name of the program you just closed).
Typically only once a program/app/whatever is completely turned off/shut down/not running/whichever vernacular you choose to use, then would you preform operations on the files that run the prog/app/etc.
