I've wrote a lisp routine, the makes an amount (defined by user) of copies, of several( selected by user) objects, along a distance, defined by 2 points (picked by user).
The program seems to do exactly what I want it to do, but:
1. It seems that the routine runs slowly, and I suppose that it is possible to improve this ) Unfortunately my knowlege of AutoLisp are not deep wnough ) so I ask you for an advise )
2. at the end, I get in the command-line area the next lines:
Command: CC Unknown command "CC". Press F1 for help.
Command: 15359
I examined my code, and I can't find what causes this problem.
I know that 15359 has to do smth. with OSMODE, but I don't see the mistake in my code
3. If it is not so hard to do, I would like a "tracing line" between first point and the second point when they are picked.
but I suppose it will need some essential changes in the code 🙂
P.S.
the routine is attached to the topic
thanks in advance )
Here's an update of one I wrote a couple years ago...
(defun c:CM (/ *error* ss p1 p2 d a) ;; Copy Multiple Times ;; Alan J. Thompson, 03.30.10 / 12.22.10 / 2013.07.05 (defun *error* (msg) (and *AcadDoc* (vla-endundomark *AcadDoc*)) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,"))) (progn (vl-bt) (princ (strcat "\nError: " msg))) ) ) (vla-startundomark (cond (*AcadDoc*) ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) ) ) (if (and (setq ss (ssget "_:L")) (setq p1 (getpoint "\nSpecify base point: ")) (setq p2 (if acet-ss-drag-move (acet-ss-drag-move ss p1 "\nSpecify next point: " T) (getpoint p1 "\nSpecify next point: ") ) ) ) (progn (setq d 0. p1 (trans p1 1 0) p2 (trans p2 1 0) a (angle p1 p2) ) (initget 6) (setq *CM:Num* (cond ((getint (strcat "\nNumber of copies <" (itoa (cond (*CM:Num*) ((setq *CM:Num* 1)) ) ) ">: " ) ) ) (*CM:Num*) ) ) (repeat *CM:Num* (setq d (+ (distance p1 p2) d)) (vlax-for x (setq ss (vla-get-activeselectionset *AcadDoc*)) (vlax-invoke (vla-copy x) 'Move p1 (polar p1 a d)) ) ) (vla-delete ss) ) ) (*error* nil) (princ) ) (vl-load-com) (princ)
@Kycau wrote:I wish there were some
;commentaries🙂
but thanks anyway 🙂
I'll browse all the unknown functions )
I wish you would just ask, but here you go any way...
(defun c:CM (/ *error* ss p1 p2 d a as) ;; Copy Multiple Times ;; Alan J. Thompson, 03.30.10 / 12.22.10 / 2013.07.05 ;; error handler (defun *error* (msg) (and *AcadDoc* (vla-endundomark *AcadDoc*)) ; undo end (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,"))) (progn (vl-bt) (princ (strcat "\nError: " msg))) ) ) ;; start undo mark (vl commands aren't recognized by undo, so if you undo afterwards ;; it will undo the last command before this one (vla-startundomark (cond (*AcadDoc*) ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) ) ) (if (and (setq ss (ssget "_:L")) ; select objects ("_:L" excludes object(s) on locked layers) (setq p1 (getpoint "\nSpecify base point: ")) ; base point for copy (setq p2 (if acet-ss-drag-move ; check if function is available. this is part of express tools (acet-ss-drag-move ss p1 "\nSpecify next point: " T) ; function is available, get next point (getpoint p1 "\nSpecify next point: ") ; function unavailable, get next point ) ) ) (progn (setq d1 0. ; set copy distance variable d2 (distance p1 p2) ; distance b/w p1 and p2 p1 (trans p1 1 0) ; translate p1 from UCS to WCS (user coordinate system to world..) p2 (trans p2 1 0) ; translate p2 from UCS to WCS a (angle p1 p2) ; get angle b/w p1 and p2 ) (initget 6) ; removes ability to enter a number 0 or less (setq *CM:Num* (cond ((getint (strcat "\nNumber of copies <" ; global variable for number of copies (itoa (cond (*CM:Num*) ((setq *CM:Num* 1)) ) ) ">: " ) ) ) (*CM:Num*) ) ) (repeat *CM:Num* ; copy object(s) based on number of copies desired (setq d1 (+ d2 d1)) ; set distance (distance (vlax-for x (cond (as) ; step through selectionset ((setq as (vla-get-activeselectionset *AcadDoc*))) ) (vlax-invoke (vla-copy x) 'Move p1 (polar p1 a d1)) ; make copy of each object and move ) ) (vla-delete as) ; delete vla selection set (doesn't actually delete objects) ) ) (*error* nil) ; execute the error for a clean close (princ) ; exit program quietly ) (vl-load-com) ; load visual lisp fucntions (princ) ; load them quietly
Also, I noticed I create the selectionset multiple times, so here's the edited version, without comments.
(defun c:CM (/ *error* ss p1 p2 d a as) ;; Copy Multiple Times ;; Alan J. Thompson, 03.30.10 / 12.22.10 / 2013.07.05 (defun *error* (msg) (and *AcadDoc* (vla-endundomark *AcadDoc*)) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,"))) (progn (vl-bt) (princ (strcat "\nError: " msg))) ) ) (vla-startundomark (cond (*AcadDoc*) ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) ) ) (if (and (setq ss (ssget "_:L")) (setq p1 (getpoint "\nSpecify base point: ")) (setq p2 (if acet-ss-drag-move (acet-ss-drag-move ss p1 "\nSpecify next point: " T) (getpoint p1 "\nSpecify next point: ") ) ) ) (progn (setq d1 0. d2 (distance p1 p2) p1 (trans p1 1 0) p2 (trans p2 1 0) a (angle p1 p2) ) (initget 6) (setq *CM:Num* (cond ((getint (strcat "\nNumber of copies <" (itoa (cond (*CM:Num*) ((setq *CM:Num* 1)) ) ) ">: " ) ) ) (*CM:Num*) ) ) (repeat *CM:Num* (setq d1 (+ d2 d1)) (vlax-for x (cond (as) ((setq as (vla-get-activeselectionset *AcadDoc*))) ) (vlax-invoke (vla-copy x) 'Move p1 (polar p1 a d1)) ) ) (vla-delete as) ) ) (*error* nil) (princ) ) (vl-load-com) (princ)
To help things along, here's the comand version (similar to yours), just slightly rewritten. I didn't comment it, because you either know what they do, or can take from the other commented one. This is easier to write, but will function a lot slower and just isn't as clean.
(defun c:test (/ ss p1 p2 num ang dst dst2) (if (and (setq ss (ssget "_:L")) (setq p1 (getpoint "\nSpecify first point: ")) (setq p2 (getpoint p1 "\nSpecify next point: ")) (progn (initget 6) (setq num (getint "\nSpecify number of copies: "))) ) (progn (setq ang (angle p1 p2) dst (distance p1 p2) dst2 0. ) (repeat num (command "_.copy" ss "" "_non" p1 "_non" (polar p1 ang (setq dst2 (+ dst dst2))))) ) ) (princ) )
