1,000 Comma Separator
15 REPLIES 15
Message 1 of 16
4668 Views, 15 Replies
Happy New Year Y'All !!
Does anyone know of, or have a lisp routine that will plug in a comma for
the 1,000 separator in multiple lines of numbers ?
Example:
1236.43 1,236.43
24562.10 24,562.10
101293.43 101,293.43
3837321.43 3,837,321.43
Can anyone help me out? Or maybe there is something already built into
Autocad that I am not aware of.
Thanks a million!
Pat
A2k6
15 REPLIES 15
Message 2 of 16
I pulled this from one of my lisp routines, original credit goes to John
Uhden
;; * == Add Commas == *
;; Code Source: John Uhden
;; This function pads a numeric string with commas.
;; Arguments:
;; num = any number, real or integer (>= 0)
;; # = precision, integer (>= 0)
(defun rtoc (num # / p#)
(setq num (rtos num 2 #) # 1)
(while (and (/= (substr num # 1) ".")(<= # (strlen num)))
(setq # (1+ #))
(setq # (1- #) p# #)
(if (= (setq # (rem # 3)) 0)(setq # 3))
(while (< # p#)
(setq num (strcat (substr num 1 #) "," (substr num (1+ #)))
# (+ 4 #)
p# (1+ p#)
num
Gilbert L. "Chip" Harper
AutoDesk Discussion Group Facilitator
Web: http://www.hot4cad.com
Message 3 of 16
Dear Chip,
What do I type in at the command prompt to get this guy going please?
Pat
"Chip Harper" wrote in message
news:5444748@discussion.autodesk.com...
Uhden
;; Arguments:
(setq # (1+ #))
(while (< # p#)
# (+ 4 #)
p# (1+ p#)
num
Message 4 of 16
You don't ... this is a function ... one piece of a larger file, this
portion just adds the commas.
This comes from a routine that I wrote to do area calculations (SF, ACRES,
etc.). You would need to write the rest of the routine or do a search on the
newsgroups and/or Google for a comma lisp.
Message 5 of 16
GODOYFP
Try this one and let me know. Just load and use as follow by typing something like this on command prompt:
(comma 123456.123 2) then you get 123,456.12
or
(comma 123456.123 0) then you get 123,456
The 1st set of number is to number to add commas to, the 2nd is the precision #. This may be used as a function also and add to your existing lisp routines.
Enjoy !
;;Function to Add Thousand comma separator to any number
;;By Felix P. Godoy
;;03/10/2004
;;revs. 04/46/2005 Clean up / More efficent
(defun comma ( Numb )
(setq lenNumb 0)
(setq lenwhole 0)
(setq lenNumb 0)
(setq decpos 0)
;(setq rBlock3 nil)
;(setq rBlock3cl nil)
(setq dunits (getvar "dimunit"))
(setq Number nil)
(setq FinalNumber nil)
(setq FoundE nil)
(setq NumberList nil)
(setq wholeList nil)
(setq rwholeList nil)
(setq strNumb (rtos Numb 2 dunits))
(setq FoundE (vl-string-search "E+" strnumb))
(setq lenNumb (strlen strNumb))
(setq decpos (vl-string-position 46 strNumb))
(if (null decpos)
(setq decpos 16)
(setq redFactor (- lenNumb decpos))
(setq wholeNumb (substr strNumb 1 decpos))
(setq wholeList (vl-string->list wholeNumb))
(setq rwholeList (reverse wholeList))
(setq rwholeNumb (vl-list->string rwholeList))
(setq lenwhole (strlen wholeNumb))
(setq startn 1)
(if (or (<= lenwhole 3) (= FoundE T))
(setq FinalNumber strNumb)
(progn
(while (/= "" rBlock3)
(setq rBlock3 (substr rwholenumb startn 3))
(setq rBlock3c (strcat rBlock3 ","))
(setq rBlock3cl (vl-string->list rBlock3c))
 (if (/= rBlock3cl nil)
 (setq NumberList (append (reverse rblock3cl) NumberList))
(setq Number (vl-list->string NumberList))
(setq FinalNumber (vl-string-left-trim ",," Number))
(setq startn (+ startn 3))
);progn
);if
(princ)
);defun
; Reverses a string
(defun revs ( string )
   (vl-list->string (reverse (vl-string->list string)))
Message 6 of 16
Kent1Cooper
in reply to: GODOYFP
It's not returning anything for me -- not nil, not an empty text string, just nothing.  Also, your usage examples show giving it two arguments, but it's written for only one, and when I paste your examples in, it confirms that I've given it too many arguments.
Kent Cooper, AIA
Message 7 of 16
bhull1985
in reply to: Kent1Cooper
You could also do it like this, which would be called by typing "rtoc" into cad, followed by the number you wish to pad and the # of decimal places beyond the number you wish to have trailing
(defun C:rtoc (/ num # p#)
(setq num (getreal "Input number to pad:"))
(setq # (getint "Precision (amount):"))
(setq # (1+ #))
(while (< # p#)
# (+ 4 #)
p# (1+ p#)
num
Minimally tested, uses getreal but I did not test if letters were inputted instead of numbers...common sense and an understanding of the english language required!
 HTH
Please use code tags and credit where credit is due. Accept as solution, if solved. Let's keep it trim people!
Message 8 of 16
GODOYFP
There are 3 things to type in parenthesis at the command prompt: (comma
number #)
1. the command: comma
2. the number to add commas to
3. the # precision
I uploaded the actual lsp routine as coma.txt. Rename it coma.lsp. Load it
by just dropping into dwg.
Now type in parenthesis something like: (this comma is w/ 2 m's)
(comma 7654321 0) then you get 7,654,321
if you type
(comma 7654321 2) then you get 7,654,321.00
if you type
(comma 7654321.5678 1) then you get 7,654,321.6
and so on...
Let me know if this helps.
Peter
Message 9 of 16
GODOYFP
Try to use this instead
;;By Felix P. Godoy 03/10/2004
;;revs. 04/16/2005 Adds thosands comma separator to any number/ Clean up / More efficient
;; Numb = any number
;; Prec = precision
(defun comma ( Numb Prec / lenNumb lenwhole decpos rBlock3 rBlock3c rblock3cl Mode Number NumberList FinalNumber FoundE Found- wholelist rwholelist wholeNumb rwholeNumb afterdec strNumb redFactor startn commaNumber)
(setq lenNumb 0)
(setq lenwhole 0)
(setq decpos 0)
(setq rBlock3 nil)
(setq Mode (getvar "dimunit"))
(setq Number nil)
(setq FoundE nil)
(setq Found- nil)
(setq strNumb (rtos Numb Mode Prec))
(setq Found- (vl-string-search "-" strnumb))
 (if (null decpos)
 (setq decpos 16)
(setq afterdec (vl-string-left-trim WholeNumb strNumb))
(setq startn 1)
 (setq commaNumber strNumb)
 (progn
   (if (= Found- 0)
   (progn
   (setq FinalNumber (vl-string-left-trim ",,-," Number))
   (setq commaNumber (strcat "-" FinalNumber afterdec))
   (progn
   (setq commaNumber (strcat FinalNumber afterdec))
   );this progn
   );this if
  (setq commaNumber commaNumber)
  );while ends
 );progn
 );if
);defun
; Reverses a string
Message 10 of 16
Kent1Cooper
number #)
3. the # precision
Load it by just dropping into dwg.
I understand all of that, and did it all before [EDIT: with your first one (Message 5)], except that I put it into a .lsp file and APPLOADed it, rather than dropping it into the drawing.  Then, pasting one of your examples directly:
Command: (comma 7654321 0)
; error: too many arguments
I haven't a clue how you're getting away with giving it two arguments, when there's only one argument item listed in the parentheses after the function name on the (defun ... line -- that's what's giving me the error message.  Is what you have loaded really the same code as what you posted?  I tried omitting the precision, so it would at least have the right number of arguments, and did:
Command: (comma 7654321)
That's when I got nothing at all, not nil, not an empty string, no error message, but it just went back to the Command: prompt.
EDIT:  I see now that the later one does account for two arguments.
However, it has a problem for people like me who use Architectural Units, I expect because of its using the DIMUNIT System Variable for the mode argument in (rtos) functions.  I get, for example:
Command: (comma 1542324.3112 3)
"12,852,7'-,0 1,/4\""
And things involving calculation can come out not as intended, like:
Command: (comma (* 123456 987675.43) 3)
"1.219E+11"
Here's the approach I took:
(defun commify (num prec / numstr intstr decstr comstr)
  (setq
    numstr (rtos num 2 prec); eliminates any scientific-notation E+ element
    intstr ; integer portion as string
      ;; (itoa (fix num)) has problem with calculated returns in scientific notation,
      ;; so use (rtos) to 0 decimal places, but that rounds, possibly upward, so:
      (if (< (- num (fix num)) 0.5)
        (rtos num 2 0)
        (rtos (1- num) 2 0)
      ); if & intstr
    decstr (substr numstr (1+ (strlen intstr))); decimal portion as string ["" if no decimal places]
    comstr (substr intstr 1 (rem (strlen intstr) 3)); begin commified string w/ part before first comma [if any]
    intstr (substr intstr (1+ (strlen comstr)))
  ); setq
  (while (>= (strlen intstr) 3)
    (setq
      comstr (strcat comstr (if (> (strlen comstr) 0) "," "") (substr intstr 1 3)); [no comma if starts with 3 digits]
      intstr (substr intstr 4)
    ); setq
  ); while
  (strcat comstr decstr); add decimals back [if any]
Which gives such results as:
Command: (commify 284725.86572 3)
"284,725.866"
Command: (commify 1 0)
"1"
Command: (commify 234 4)
"234.0000"
Command: (commify 95738462.4 2)
"95,738,462.40"
Command: (commify pi 10)
"3.1415926536"
Command: (commify (* 123456 987675.43) 3)
"121,934,457,886.080"
Command: (commify (expt 2.5 😎 4)
"1,525.8789"
Kent Cooper, AIA
Message 11 of 16
GODOYFP
I had posted an OLD version. Did you see my new post/email?
Here it is again...
More efficient
;; Prec = precision
commaNumber)
(setq lenNumb 0)
(setq lenwhole 0)
(setq decpos 0)
(setq rBlock3 nil)
(setq Number nil)
(setq FoundE nil)
(setq Found- nil)
(if (null decpos)
(setq decpos 16)
(setq startn 1)
(progn
(if (= Found- 0)
(progn
(progn
);this progn
);this if
);while ends
);progn
);if
);defun
; Reverses a string
*** Enjoy !!! ***
Message 12 of 16
Kent1Cooper
[Yes -- we obviously "crossed in the mail" with your latest and my editing my previous reply, q.v.]
Kent Cooper, AIA
Message 13 of 16
Lee_Mac
This looked like fun - here is my version:
(defun rtoc ( n p / d i l x )
    (setq d (getvar 'dimzin))
    (setvar 'dimzin 0)
    (setq l (vl-string->list (rtos n 2 p))
          x (cond ((cdr (member 46 (reverse l)))) ((reverse l)))
          i 0
    (setvar 'dimzin d)
    (vl-list->string
        (append
            (reverse
                (apply 'append
                    (mapcar
                       '(lambda ( a b )
                            (if (and (zerop (rem (setq i (1+ i)) 3)) b)
                                (list a 44)
                                (list a)
                        x (append (cdr x) '(nil))
            (member 46 l)
@Kent, be careful when DIMZIN=8 Smiley Wink
Message 14 of 16
Lee_Mac
in reply to: Lee_Mac
Another to account for negatives:
    (setvar 'dimzin 0)
    (setq l (vl-string->list (rtos (abs n) 2 p))
          i 0
    (setvar 'dimzin d)
    (vl-list->string
        (append (if (minusp n) '(45))
            (reverse
                (apply 'append
                    (mapcar
                       '(lambda ( a b )
                                (list a 44)
                                (list a)
            (member 46 l)
And a recursive variation:
(defun rtoc ( n p / foo d l )
    (defun foo ( l n )
        (if (or (not (cadr l)) (= 46 (cadr l)))
            l
            (if (zerop (rem n 3))
                (vl-list* (car l) 44 (foo (cdr l) (1+ n)))
                (cons (car l) (foo (cdr l) (1+ n)))
    (setvar 'dimzin 0)
    (setq l (vl-string->list (rtos (abs n) 2 p)))
    (setvar 'dimzin d)
    (vl-list->string
            (foo l (- 3 (rem (fix (/ (log (abs n)) (log 10))) 3)))
Message 15 of 16
GODOYFP
Nice... Very short.
Message 16 of 16
pbejse
Another
(defun _comma (n p / a b m i lst)
(setq dz (getvar 'dimzin))
(setvar 'Dimzin 0)
(setq str (rtos (abs n) 2 p))
(setvar 'Dimzin dz)
	(setq a	(vl-filename-base str)
	      b	(substr str (1+ (strlen a)))
	      m	(vl-string->list a)
	      i	(length m) lst nil)
	(while (>= i 3)
	(setq lst (append (list 44
		   (nth (- i 3) m)
	           (nth (- i 2) m)
	           (nth (1- i) m)) lst ) i ( - i 3)) lst )
	(strcat (if (minusp n) "-" "")(substr str 1 i)
		(vl-list->string (if (zerop i) (cdr lst) lst))
		b))
 [Not thorougly tested]
”Boost
