Visual Basic Customization
Active Contributor
lanieuwe
Message 1 of 2 (197 Views)
Accepted Solution
step through layers with vba?
197 Views, 1 Replies
12-20-2012 02:01 AM
I am working with a lisp that step through layers one at a time, locking all other layers than current one. (enter or space)
While this lisp runs I can zoom etc in the drawing.
Is it possible to make this tool with VBA too?
gr. Laszlo
defun C:STL (/ *error* cmde lay)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg))
    ); end if
    (command "_.layer" "_unlock" "*" "")
    (setvar 'cmdecho cmde)
  ); end defun - *error*
  (setq cmde (getvar 'cmdecho))
  (setvar 'cmdecho 0)
  (while (getstring "\nPress Space or Enter to go to next Layer, Escape to quit: ")
    (setq lay (cdr (assoc 2 (tblnext "layer" (not lay)))))
 (while (and lay (wcmatch lay "*|*") (setq lay (cdr (assoc 2 (tblnext "layer"))))));
(if (not lay) (setq lay (cdr (assoc 2 (tblnext "layer" T))))); back to 0 at end
    (command "_.layer" "_thaw" lay "_set" lay "_lock" "*" "_unlock" lay "" "_regen")
  ); end while
); end defun
(princ "\nType STL to Step Through Layers, locking all other Layers.")
(princ)
truss_85
Message 2 of 2 (182 Views)
Re: step through layers with vba?
12-21-2012 06:07 AM in reply to: lanieuwe
I am afraid it is not but it might be possible another way but you can execute command each time. It continues to which layer did you left.
You are not logged in.
Announcements
Need installation help?
Ask the Community
