Visual Basic Customization
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*UItaly
read and set the attributes of blocks in windows 64 bit
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
288 Views, 2 Replies
02-24-2010 10:55 PM
Hello everyone
I read and set the attributes of blocks using VBA in AutoCAD 2010 on
Windows 64 bit.
In Windows 32-bit I always used the following code without problems:
NposScr = elem.GetBlockAttributeValue(o.ObjectID)
and
Call oML.SetBlockAttributeValue(o.ObjectID, "TEST")
But now in Windows 64 bit does not work.
I tried to replace o.ObjectID with o.ObjectID32 and early seemed to
work, but after a while 'has begun to indicate the following error:
Compile error: Function or interface marked as restricted, or the
funzion uses an Automation type not supported in Visual Basic
I want a code that works with both Windows 64-bit and 32 bit Windows.
Can you help?
Windows 64 bit.
and
Can you help?
*Tony Tanzillo
Re: read and set the attributes of blocks in windows 64 bit
Options
- Highlight
- Email to a Friend
02-25-2010 11:21 AM in reply to:
*UItaly
Well, you're going to have to think about migrating to VB.NET.
The problem appears to be that 64 bit integers are not a type
supported by ActiveX.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
"UItaly" wrote in message
news:6343854@discussion.autodesk.com...
Hello everyone
Windows 64 bit.
and
Can you help?
"UItaly"
Hello everyone
Windows 64 bit.
and
Can you help?
Options
- Highlight
- Email to a Friend
10-04-2012 12:03 PM in reply to:
*UItaly
Hello, I've been wrestling with this too. If you use GetBlockAttributeValue32 instead of GetBlockAttributeValue it should work. I know this is a couple years old, but I've had success with this: ex: strDesc = acdMleader.GetBlockAttributeValue32(oAttDef.Object ID32) Regards, Stephen Schneider
