• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Visual Basic Customization
    *Elmore, Andrew
    programs to work with 04 & 03
    42 Views, 5 Replies
    07-29-2003 10:14 AM
    How can I add references in my projects to work with ADT 3.3 and 04. I use
    04 but some people are still useing 3.3 so I need both refs.
    Andy
    Please use plain text.
    *P., Danny
    Re: programs to work with 04 & 03
    07-30-2003 05:09 AM in reply to: *Elmore, Andrew
    Andrew,
    I would venture a guess that you can't do this. This was an issue with 3.0
    & 3.3, and it required us to maintain 2 versions, one for 3.0 and one for
    3.3. Although I haven't tested it, I would say that this is still true.
    You might also try posting this in the
    autodesk.aec.arch-desktop.customization newsgroup. Some of the ADT API
    developers lurk there and will probably post back.
    Hope that helps,
    -Danny Polkinhorn
    Perkins & Will
    Atlanta
    "Andrew Elmore" wrote in message
    news:997ECFDE9CB228122E33A8F6A95A7AB5@in.WebX.maYIadrTaRb...
    > Thanks,
    > Andy
    *Elmore, Andrew
    Re:
    07-30-2003 06:22 AM in reply to: *Elmore, Andrew
    Thanks I'll give it a try.
    Andy
    "Danny P." wrote in message
    news:6DAE2A3302775580E6BA66645FE511D3@in.WebX.maYIadrTaRb...
    > Andrew,
    3.0
    > Hope that helps,
    > -Danny Polkinhorn
    > Perkins & Will
    > Atlanta
    use
    > > Thanks,
    > > Andy
    *Comerford, Laurie
    07-30-2003 11:14 AM in reply to: *Elmore, Andrew
    Hi Andrew,
    I have been trying to resolve this issue in a desultary fashion for some
    time.
    The information below comes from the AUGI VBA Guild. It start with Richard
    Binning providing information which I tried and I succeeded in loading the
    ALD libraries based on Richard's suggestions.
    However, I could not get my code to recognise that the libraries were
    loaded.
    The top message posted today by Ed Jobe in the AUGI VBA guild is my next
    port of call.
    I haven't had time to try Ed's suggestions yet, but the more of us that try,
    the more likely we will be to get a working answer.
    Lastly, I have some information from Autodesk, that the process may be
    affected by a bug in the AutoCAD API's and for the moment it may not work
    anyhow with R2004.
    Laurie Comerford
    CADApps
    www.cadapps.com.au
    ----- Original Message -----
    To: guild-vba@augi.com
    Sent: Thursday, July 31, 2003 4:03 AM
    Subject: [VBA] Setting references programmatically
    A while back, someone asked how to set references programmatically, as
    in when you have different versions of a program you need to reference.
    The requestor was having trouble with the vbaide prompting to save the
    project after the reference was set. I just now had time to check into
    it. If you clean up after yourself, deleting the reference, you won't
    have this problem. I modified my functions to allow for this. I also
    added one to set the ref by GUID. That way you don't have to worry about
    checking for a valid file path. You can get the necessary GUID info
    using the sample sub below.
    Sub testref1()
    'Sample to demonstrate working with references
    'Set reference for ADO.
    '"Microsoft AcitveX Data Objects library 2.7"
    Dim objRef As vbide.Reference
    Set objRef = SetReferenceByFile("C:\Program Files\Common
    Files\system\ado\msado15.dll")
    ' Set objRef =
    SetReferenceByGUID("{EF53050B-882E-4776-B643-EDA472E8E3F2}", 2, 7)
    If objRef Is Nothing Then
    MsgBox Err.Number & ", " & Err.Description, vbExclamation,
    "Error setting reference."
    Else
    Debug.Print objRef.Guid & ", " & objRef.Major & ", " &
    objRef.Minor
    End If
    DeleteReference objRef
    End Sub
    Public Function DeleteReference(ref As vbide.Reference)
    On Error GoTo ErrorHandler
    Dim objVB As VBE
    Dim objRef As Reference
    Set objVB = Application.VBE
    objVB.ActiveVBProject.References.Remove ref
    GoTo Finish:
    ErrorHandler:
    "Error deleting reference."
    Finish:
    Set objVB = Nothing
    End Function
    Public Function SetReferenceByFile(filepath As String, Optional
    DisplayErrors As Boolean) As vbide.Reference
    'Returns a Reference object if successful in setting a reference in
    the current dvb,
    'given the FilePath of a tlb, olb, dll. The DisplayErrors option
    determines
    'whether or not an error message will be displayed upon erroring.
    Dim objVB As VBE
    Dim objRefs As vbide.References
    Dim strPath As String
    Set objRef =
    objVB.ActiveVBProject.References.AddFromFile(filepath)
    Set SetReferenceByFile = objRef
    GoTo Finish:
    ErrorHandler:
    If Err.Number = 32813 Then
    'reference was already set, just return True
    Set objRefs = objVB.ActiveVBProject.References
    For Each objRef In objRefs
    If objRef.FullPath = filepath Then
    End If
    Next objRef
    Else
    If DisplayErrors = True Then
    Else
    End If
    Set SetReferenceByFile = Nothing
    End If
    Finish:
    Set objVB = Nothing
    Set objRef = Nothing
    End Function
    Public Function SetReferenceByGUID(strGUID As String, maj As Long, min
    As Long) As vbide.Reference
    the current dvb,
    'given the GUID of a tlb, olb, dll. Using a GUID avoids having to
    test
    'for a valid filepath.
    Dim objVB As VBE
    Set objRef = objVB.ActiveVBProject.References.AddFromGuid(strGUID,
    1, 1)
    Set SetReferenceByGUID = objRef
    GoTo Finish:
    ErrorHandler:
    Else
    Set SetReferenceByGUID = Nothing
    End If
    Finish:
    Set objVB = Nothing
    End Function
    Ed Jobe
    guild-lisp-moderator@augi.com
    guild-mdt-moderator@augi.com
    ---footer---
    You are receiving this message because you are subscribed to
    guild-vba@augi.com. If you wish to unsubscribe from this list, please send
    an email to mailto:guild-vba-request@augi.com?Subject=unsubscribe with the
    word "unsubscribe" (without the quotes) in the subject of the email and
    follow any instructions that follow. If you require any help with
    subscription matters or general Guild information then please send an email
    to mailto:guild-list-moderators@augi.com.
    To: 'kdayman@UMAGroup.com' ; VBA Guild (guild-vba@augi.com)
    Sent: Wednesday, July 23, 2003 10:44 PM
    Subject: Re: [VBA] FW: Loading References when ALD but not Vanilla ACAD
    You can check the registry for the application that is running the macro.
    Check the "default" value of this key:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App
    Paths\acad.exe
    From the path to the executable, you should be able to detect what flavor
    the application
    is.
    You could also check the current profile with a function like that shown
    below:
    Function Get_ActiveProfile() As String
    ' This function returns the current setting of
    ' ActiveProfile.
    On Error Goto Err_Relief
    Dim preferences As AcadPreferences
    Dim currActiveProfile As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current ActiveProfile value
    currActiveProfile = preferences.Profiles.ActiveProfile
    Err_Relief:
    If Len(currActiveProfile) < 1 then
    msgbox "Error detected, profile unknown!"
    Else
    Get_ActiveProfile = currActiveProfile
    End if
    Set preferences = Nothing
    End Function
    To set a reference to a particular library, you will have to add a reference
    to the microsoft vba extensibility 5.3 library.
    You can then declare some objects to hold the reference values such as:
    Dim oVBE As VBIDE.VBE
    Dim oVBP As VBIDE.VBProject
    Dim oVBPs as VBIDE.VBProjects
    Dim oVBR As VBIDE.Reference
    Dim oVBRs As VBIDE.References
    Now populate your objects...
    Set oVBE = Application.VBE
    Set oVBPs = oVBE.VBProjects
    Set oVBP = oVBPs("Your project title")
    Set oVBRs = oVBP.References
    You should be able to try attaching your desired ref here and do some
    trapping.
    On Error Resume Next
    Set oVBR = oVBRs("Your Type Library")
    If Err then
    'clean it up
    else
    'restore proper error handling here
    endif
    Does that give you enough to get started?
    P.S. I wrote that on the fly not in the VBA editor so I might have some
    error of exclusion or spelling.
    Richard Binning
    AUGI Guild Moderator
    AUGI Exchange Approvals Manager
    Member # 15067
    Win2k SP2
    Acad 2002
    Architectural Desktop 3.3 SP2
    Land Development Desktop 3.0
    Building Systems 3.0
    PIV 1.3 GHZ
    512 RAM
    OXYGEN GVX1 32mb AGP
    Mailto: guild-cadmgr-moderator@augi.com
    > -----Original Message-----
    > From: Kelly Dayman (Bur) [mailto:kdayman@UMAGroup.com]
    > Sent: Tuesday, July 22, 2003 7:39 PM
    > To: VBA Guild (guild-vba@augi.com)
    > Subject: [VBA] FW: Loading References when ALD but not Vanilla ACAD
    > Sent: Tuesday, July 22, 2003 4:28 PM
    > To: 'Wes Stueve'; Kelly Dayman (Bur)
    > Subject: RE: [VBA] Loading References when ALD but not Vanilla ACAD
    > Thanks Wes, triggered some ideas but no result (stupid brain).
    > By big problem is how to load a reference at run time?
    > Thanks,
    > Kelly
    > From: Wes Stueve [mailto:Wes.Stueve@hendersonengineers.com]
    > Sent: Tuesday, July 22, 2003 3:23 PM
    > To: kdayman@UMAGroup.com
    > Which part fails? Does the AeccApplication application
    > object exist on
    > machines without ALD? If that is the case, you can say
    > (after removing the
    > reference):
    > Dim obj
    > Set obj = GetObject(,"[REFERENCELIB].AeccApplication")
    > If Err.Number <> 0 Then
    > 'it is not on this machine
    > End if
    > The reference library should be able to be found in the
    > registry. Just do a
    > search for AeccApplication until you find something that
    > looks right. Look
    > at the GetObject and CreateObject functinons for help on
    > locating this.
    > Don't know if this helps you or not, but good luck!
    > Wes
    > Sent: Tuesday, July 22, 2003 5:12 PM
    > To: 'Laurie Comerford'; Kelly Dayman (Bur); guild-vba@augi.com
    > Subject: Re: [VBA] Loading References when ALD but not Vanilla ACAD
    > I want to only load the ALD Library if ALD is the application that is
    > running the VBA. However if I reference the library then try
    > to run on a
    > station that does not have ALD the VBA application gets very upset.
    > I know this is possible I was involved in a thread that
    > discussed it about 4
    > months ago, however I have changed computers since then and I did not
    > transfer the info over. As soon as you get rid of something
    > you need it!!
    > Kelly
    > From: Laurie Comerford [mailto:laurie@cadapps.com.au]
    > Sent: Tuesday, July 22, 2003 3:12 PM
    > To: kdayman@UMAGroup.com; guild-vba@augi.com
    > Hi Kelly,
    > I doubt that it would be legal for you to use ALD library
    > files on non-ALD AutoCADs.
    > One way of dealing with the issue is to include the library
    > as a reference
    > in your program and then call the program with a lisp
    > function which checks
    > the AutoCAD version which is running and returns an error
    > message if it's
    > not ALD.
    > Laurie Comerford
    > CADApps
    > www.cadapps.com.au <>
    > Sent: Wednesday, July 23, 2003 3:48 AM
    > Subject: [VBA] Loading References when ALD but not Vanilla ACAD
    > I am working on a routine that will run on many different
    > platform ALD, ACAD
    > etc. When ALD is the current app I need to run the following
    > statement:
    > AeccApplication.ActiveDocument.Preferences.databasescale = dblScale
    > However I must load the associated Reference when in ALD in
    > order for this
    > to work, machines without ALD will not have this reference available.
    > Reference Lib AUTODESK LAND 1.2 TYPR LIBRARY
    > What is the best method to check if the app is ALD and load
    > the library in
    > the code?
    > Kelly Dayman
    > UMA Group Ltd.
    ---footer---
    > Thanks,
    > Andy
    *Elmore, Andy
    Re:
    08-04-2003 02:21 PM in reply to: *Elmore, Andrew
    test
    "Laurie Comerford" wrote in message
    news:914024A6EE61D23528FAE9C425655CC9@in.WebX.maYIadrTaRb...
    > Hi Andrew,
    > time.
    Richard
    > loaded.
    > port of call.
    try,
    > anyhow with R2004.
    > Laurie Comerford
    > CADApps
    > www.cadapps.com.au
    > From: Ed Jobe
    > Sub testref1()
    > ' Set objRef =
    > Else
    > objRef.Minor
    > End If
    > End Sub
    > Dim objVB As VBE
    > GoTo Finish:
    > ErrorHandler:
    > Finish:
    > Set objVB = Nothing
    > End Function
    > the current dvb,
    > determines
    > Dim objVB As VBE
    > Set objRef =
    > GoTo Finish:
    > ErrorHandler:
    > End If
    > Next objRef
    > Else
    > Else
    > End If
    > End If
    > Finish:
    > Set objVB = Nothing
    > End Function
    > the current dvb,
    > test
    > Dim objVB As VBE
    > 1, 1)
    > GoTo Finish:
    > ErrorHandler:
    > Else
    > End If
    > Finish:
    > Set objVB = Nothing
    > End Function
    > Ed Jobe
    > ---footer---
    email
    > From: Binning, Richard L.
    > Paths\acad.exe
    > the application
    > is.
    > below:
    > ' ActiveProfile.
    > Err_Relief:
    > Else
    > End if
    > End Function
    reference
    > trapping.
    > If Err then
    > 'clean it up
    > else
    > endif
    > Richard Binning
    > Member # 15067
    > Win2k SP2
    > Acad 2002
    > PIV 1.3 GHZ
    > 512 RAM
    > > Thanks,
    > > Kelly
    > > object exist on
    > > (after removing the
    > > reference):
    > > Dim obj
    > > End if
    > > registry. Just do a
    > > looks right. Look
    > > locating this.
    > > Wes
    > > to run on a
    > > you need it!!
    > > Kelly
    > > Hi Kelly,
    > > as a reference
    > > message if it's
    > > not ALD.
    > > Laurie Comerford
    > > CADApps
    > > platform ALD, ACAD
    > > statement:
    > > order for this
    > > the library in
    > > the code?
    > > Kelly Dayman
    > > UMA Group Ltd.
    > ---footer---
    email
    use
    > > Thanks,
    > > Andy
    *Elmore, Andrew
    Re:
    08-06-2003 01:03 AM in reply to: *Elmore, Andrew
    I have not tried this but.... maybe if I use more class libraries to
    interface with acad then over comeing different version could be easier. So
    if I had to classes 1 for 04 other for 3.3 then I could call into them to
    get what I need.
    imports ADT_class4
    imports ADT_class3
    imports AutoCAD
    try
    Dim Acad_con4 as new ADT_class4
    Dim Acad_app3 as new ADT_class3
    Dim Acad_app as AcadApplication
    Dim Acad_doc as AcadDocument
    try
    Acad_app=Acad_con4.Application
    catch
    try
    Acad_app=Acad_con3.Application
    catch
    msgbox("Did not work!")
    end try
    end try
    Catch
    end try
    > Hi Andrew,
    > time.
    Richard
    > loaded.
    > port of call.
    try,
    > anyhow with R2004.
    > Laurie Comerford
    > CADApps
    > www.cadapps.com.au
    > From: Ed Jobe
    > Sub testref1()
    > ' Set objRef =
    > Else
    > objRef.Minor
    > End If
    > End Sub
    > Dim objVB As VBE
    > GoTo Finish:
    > ErrorHandler:
    > Finish:
    > Set objVB = Nothing
    > End Function
    > the current dvb,
    > determines
    > Dim objVB As VBE
    > Set objRef =
    > GoTo Finish:
    > ErrorHandler:
    > End If
    > Next objRef
    > Else
    > Else
    > End If
    > End If
    > Finish:
    > Set objVB = Nothing
    > End Function
    > the current dvb,
    > test
    > Dim objVB As VBE
    > 1, 1)
    > GoTo Finish:
    > ErrorHandler:
    > Else
    > End If
    > Finish:
    > Set objVB = Nothing
    > End Function
    > Ed Jobe
    > ---footer---
    email
    > Paths\acad.exe
    > the application
    > is.
    > below:
    > ' ActiveProfile.
    > Err_Relief:
    > Else
    > End if
    > End Function
    reference
    > trapping.
    > If Err then
    > 'clean it up
    > else
    > endif
    > Richard Binning
    > Member # 15067
    > Win2k SP2
    > Acad 2002
    > PIV 1.3 GHZ
    > 512 RAM
    > > Thanks,
    > > Kelly
    > > object exist on
    > > (after removing the
    > > reference):
    > > Dim obj
    > > End if
    > > registry. Just do a
    > > looks right. Look
    > > locating this.
    > > Wes
    > > to run on a
    > > you need it!!
    > > Kelly
    > > Hi Kelly,
    > > as a reference
    > > message if it's
    > > not ALD.
    > > Laurie Comerford
    > > CADApps
    > > platform ALD, ACAD
    > > statement:
    > > order for this
    > > the library in
    > > the code?
    > > Kelly Dayman
    > > UMA Group Ltd.
    > ---footer---
    email
    use
    > > Thanks,
    > > Andy
