Hi All,
I find the Mistake
Thanks.
"Amrit" wrote in message
news:6295712@discussion.autodesk.com...
Hi All
I Don't know What wrong. When i plottofile it make my HDD Full. i have
attached LvPlot Image also. Please help
{code}
Private Sub CmdPrint_Click()
Dim i As Long
Dim AcDoc As AcadDocument
' On Error GoTo CmdPrint_Click_Error
Dim lay As AcadLayout
Dim x As Long
Dim MediaNames As Variant
Dim nName As Variant
Dim siz As Variant
Dim n As Long
For i = 1 To LvPlot.ListItems.Count
Header ' this is just for create object and Set AcadDoc =
AcadApp.ActiveDocument
AcadDoc.SetVariable "BACKGROUNDPLOT", 0
Set AcDoc = AcadApp.ActiveDocument
AcadDoc.Application.Documents.Open LvPlot.ListItems(i).Tag & "\" &
LvPlot.ListItems(i).SubItems(1)
Set AcadDoc = AcadApp.ActiveDocument
NextJump:
For x = 0 To AcadDoc.Layouts.Count
If AcadDoc.Layouts(x).Name = LvPlot.ListItems(i).SubItems(2) Then '
checking if layout name is match
AcadDoc.ActiveLayout = AcadDoc.Layouts(x)
AcadDoc.Application.ZoomExtents ' ZoomAll
AcadDoc.ActiveLayout.RefreshPlotDeviceInfo
AcadDoc.ActiveLayout.StyleSheet = LvPlot.ListItems(i).SubItems(7)
'Plot Style Table
AcadDoc.ActiveLayout.ConfigName = LvPlot.ListItems(i).SubItems(3)
'Printer
MediaNames = Layout.GetCanonicalMediaNames()
For n = LBound(MediaNames) To UBound(MediaNames)
nName = Layout.GetLocaleMediaName(MediaNames(n))
If nName = LvPlot.ListItems(i).SubItems(4) Then
AcadDoc.ActiveLayout.CanonicalMediaName =
MediaNames(n) 'Paper Size
Exit For
Next
AcadDoc.ActiveLayout.PlotType = acExtents
AcadDoc.ActiveLayout.PlotRotation = 0
'LvPlot.ListItems(i).SubItems(8) 'Plot Rotation
AcadDoc.ActiveLayout.CenterPlot = True
AcadDoc.ActiveLayout.StandardScale = acScaleToFit
Call AcadDoc.Plot.PlotToFile(Replace(AcadDoc.FullName, "dwg",
LvPlot.ListItems(i).SubItems(2)), LvPlot.ListItems(i).SubItems(3))
''======================================= When Plot start , It not
end==========================================
Next x
If i < LvPlot.ListItems.Count Then
If LvPlot.ListItems(i + 1).SubItems(1) = LvPlot.ListItems(i).SubItems(1)
Then
i = i + 1
GoTo NextJump
AcadDoc.Close True, LvPlot.ListItems(i).Tag & "\" &
AcadDoc.SetVariable "BACKGROUNDPLOT", 1
Next i
On Error GoTo 0
Exit Sub
CmdPrint_Click_Error:
MsgBox "Error " & Err.Number & " (" & Err.Description & ") in procedure
CmdPrint_Click of Form FrmPlotSetting"
End Sub
{\code}
