VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
multiple dimension dxf generation
4 REPLIES 4
arnold_noel
492 Views, 4 Replies
hello,
i have created a simle part file which has a User parameter (L). The part should be cut with a laser cutting machine.
My problem is, that there is 76 different dimensions for L parameter. So I have to generate 76 different dxf drawing.
is there a way to crearte a VBA code for modifying the L parameter, regenerate the part file, and export the surface of the part file as a DXF file?
regards,
arnold
4 REPLIES 4
Hallex
in reply to: arnold_noel
My guess is to wrte a functiont hat will draw your detail, depending on the value of the L parameter,
and then select the newly created item and then write selection to a dwg file using WBLOCK ,
then open it and resave a file as dxf and at the end delete previous dwg file usingKILL method
Hallex
Here is quick example, was written in a hurry,
so check all names and value
''--- Borrowed from on Juergen Menzi ---''
Public Sub WblockSelection(detailName As String, Lparam As Double)
  Dim wdoc As AcadDocument
  Dim SelSet As AcadSelectionSet
  Set SelSet = NewSelectionSet("WBLOCK_SET")
  With ThisDrawing
    SelSet.SelectOnScreen
   Dim path As String
   path = .FullName
   Dim dwgName As String
   dwgName = detailName & "_" & Replace(CStr(Lparam), ",", "_", 1, -1, vbTextCompare)
   Dim outFile As String
   outFile = .GetVariable("dwgprefix")
   outFile = outFile & dwgName & ".dwg"
  .Wblock outFile, SelSet
  End With
  Dim dxfFolder As String
  dxfFolder = "C:\Test\DxfFolder\"
  Dim dxfName As String
  dxfName = dxfFolder & dwgName & ".dxf"
Set wdoc = Application.Documents.Open(outFile, False, "")
Call wdoc.SaveAs(dxfName, ac2000_dxf, Nothing)
wdoc.Close
Kill outFile
End Sub
Public Function NewSelectionSet(AssNme As String) As AcadSelectionSet
  Dim SelCol As AcadSelectionSets
  With ThisDrawing
    Set SelCol = .SelectionSets
    For Each SelSet In SelCol
      If SelSet.Name = AssNme Then
        .SelectionSets.Item(AssNme).Delete
        Exit For
      End If
    Next
    Set SelSet = .SelectionSets.Add(AssNme)
  End With
  Set NewSelectionSet = SelSet
End Function
Public Sub Test_Wblock()
Dim lpar As Double
lpar = 1200.5
Dim shp As String
shp = "FOO"
Call WblockSelection(shp, lpar)
End Sub
arnold_noel
in reply to: Hallex
thanks for the example.
is this for autocad?
I have 3-4 dimensions driven of this L parameter. can the part generation be done in autocad?
i don't really understand ehat are you doing in the NewSelectionSet function.
your function should update the part with the new dimensions?
Hallex
This code will work with existing details, say if these has different L parameter
and yoiu now yhis value as well as detail name then you can create dxf's using this code
Or you wanted be on another lanfguage, say VB.NET or C#?
Also you could be uppload the picture here to show your detail
But sorry I can more help. some my own proble occurs
”Boost
