VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
loft and the ugly sendcommand
2 REPLIES 2
528 Views, 2 Replies
hello everyone,
i know you should never use sendcommand but its  last chance saloon time.
i already have created 2 circles:
Set objCircle1 = ThisDrawing.ModelSpace.AddCircle(objLine.startpoint, dblDia1 / 2)
Set objCircle2 = ThisDrawing.ModelSpace.AddCircle(objLine.endpoint, dblDia / 2)
now i would like to loft between them, they are not concentric else i would use AddRevolvedSolid.
how do i structure the loft command? i guess i need to send the id or handle of these circles
so i tried
strHandle1 = objCircle1.Handle
strHandle2 = objCircle2.Handle
this doesnt work:
ThisDrawing.SendCommand "loft" & vbCr &  strHandle1 &  strHandle2 & vbCr & vbCr
how do i correctly send objects to the command line?
any useful input would be wonderful! thanks
2 REPLIES 2
Alfred.NESWADBA
try this with your handles instead of mine from my small sample
   Dim tHandleStr1 As String: tHandleStr1 = "25E"
   Dim tHandleStr2 As String: tHandleStr2 = "25D"
   Call ThisDrawing.SendCommand("_LOFT" & vbCr & "(handent """ & tHandleStr1 & """)" & vbCr & "(handent """ & tHandleStr2 & """)" & vbCr & vbCr & vbCr)
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
thanks very much, that works fine. the devil is in the details!
”Boost
