Visual Basic Customization
Active Member
chris.bird
Message 1 of 2 (117 Views)
is there a way to import custom vba's from microstation to acad2011
117 Views, 1 Replies
07-27-2011 09:37 AM
I have multiple vba's written for microstation and I was wondering if there is a way to import them into acad2011.
Are there any similarities between the two pltforms in regards to vbas?
Valued Mentor
TerryDotson
Message 2 of 2 (112 Views)
Re: is there a way to import custom vba's from microstation to acad2011
07-27-2011 01:39 PM in reply to: chris.bird
In Microstations VBA IDE you should be able to export the code to FRM/FRX and BAS files.  These files could then be imported in AutoCAD's VBA IDE.  Then comes the problems:
First, there are bound to be procedures specific to getting/creating objects and more that are MSTA specific.  Those will have to be changed to accomodate the differences in AutoCAD.  It won't be as simple at export/import.
Second, unless you plan to stay with 2011/2012 forever, why bother.  It is rumored (or possibly stated) that Autodesk will remove VBA at some point in the near future.
In summary the best choice would be a complete rewrite using the Managed .NET API.  This would provide the conversion with an actual future and result in a better, faster application.
You are not logged in.
Announcements
Need installation help?
Ask the Community
