I no longer am able to switch my "anchored" tools from text to icons after upgrading to 2014. I migrated my 2013 settings, which were migrated from 2012, and it's always worked in the past, but now the option is grayed out. I've attached a screen shot to illustrate.
Is there a command I could do that would reset the ability to do this without losing my workspace settings?
Also, I have tried loading an "out-of-the-box" workspace and attempted to switch from text to icons and it too was grayed out.
Thanks in advance.
Solved by Alfred.NESWADBA. Go to Solution.
set LOCKUI to 0, then you can change it (>>>details<<<)
- alfred -
