Hi, just a litle part of help file.
An application can use the findfile function to search for a particular file name. The application can specify the directory to search, or it can use the current AutoCAD library path.
In the following code fragment, findfile searches for the requested file name according to the AutoCAD library path:
Nil = not found
If your path is not in library path, you must indicate it.
Daniel OLIVES
Lyon, FRANCE
