Visual Basic Customization
vidjeane
Message 1 of 6 (417 Views)
extract attribute values from an block in an External Reference using VBA ?
417 Views, 5 Replies
03-23-2013 05:59 AM
is it possible to extract attribute values from an block in an External Reference using VBA ?
Vidjeane.M
Alfred.NESWADBA
Message 2 of 6 (415 Views)
Re: extract attribute values from an block in an External Reference using VBA ?
03-23-2013 06:13 AM in reply to: vidjeane
yes, you will have to go into the database of the XRef, then you have access to the blockreference, and so to the attribute-values.
- alfred -
Alfred NESWADBA
vidjeane
Message 3 of 6 (408 Views)
03-23-2013 06:30 AM in reply to: Alfred.NESWADBA
Thank you Alfred.
did you see anthing i missed as in your concept?
After setting filter code & Filter Value, the code:
blkset.Select acSelectionSetAll, , , fitype, fidata
'Debug.Print vbCrLf & blkset.Count
If blkset.Count > 0 Then
i = 0: j = 0: k = 0
Do While clname = "" And i < blkset.Count
    Set tmpblk = blkset.Item(i)
        If TypeOf tmpblk Is AcadExternalReference Then
            For j = 0 To ThisDrawing.Blocks.Count - 1
                Set xrblk = ThisDrawing.Blocks.Item(j)
                If xrblk.Name = "MYXREF" Then
                    Set xrda = xrblk.XRefDatabase
                    For k = 0 To xrda.Blocks.Count - 1
                    'For j = 0 To ThisDrawing.Blocks.Count - 1
                        entname = xrda.Blocks.Item(j).Name
                        If entname = "MYXREF|BLKWITHATTRIBS" Then
                            clname = "MYXREF|BLKWITHATTRIBS"
                            xrtype = "xref"
                            Exit For
                        End If
                    Next k
                Else
                    If clname <> "" Then
                    Exit For
                    End If
                End If
            Next j
        Else
            Set blkobj = ThisDrawing.Blocks.Item(tmpblk.Name)
            xrtype = "block"
        End If
       Exit Do
     Else
         i = i + 1
     End If
Loop
Else
Vidjeane.M
Vidjeane.M
vidjeane
Message 4 of 6 (407 Views)
03-23-2013 06:36 AM in reply to: Alfred.NESWADBA
Thank you Alfred.
i = 0: j = 0: k = 0
                            xrtype = "xref"
                            Exit For
                        End If
                    Next k
                Else
                    Exit For
                    End If
                End If
            Next j
        Else
            xrtype = "block"
        End If
       Exit Do
     Else
         i = i + 1
     End If
Loop
Else
the problem is i am not getting clname. it always returns "".
Vidjeane.M
Vidjeane.M
Alfred.NESWADBA
Message 5 of 6 (399 Views)
03-23-2013 06:46 AM in reply to: vidjeane
Not tried, but I guess your string to verify the name of the blockdefinition within the XRef might be wrong.
If you open the database from the XRef, you have blocks with names, and as long as in that database there were no XRefs bound the name "MYXREF|BLKWITHATTRIBS" will not be valid, try "BLKWITHATTRIBS" in the "if"-line instead.
If that don't work do a
   Debug.Print entname
a line before your if and you see what names are found as blockdefinitions in the XRef.
to come back to your title: this just scans the block definitions within the XRef, it does not access the BlockReferences in ModelSpace (or any other space or blockdefinition if needed)
- alfred -
Alfred NESWADBA
vidjeane
Message 6 of 6 (374 Views)
03-25-2013 02:38 AM in reply to: Alfred.NESWADBA
alfred,
thakn you for your feedback.
will try & update you on this.
regards,
Vidjeane.M
Vidjeane.M
You are not logged in.
Ask the Community
