is it possible to extract attribute values from an block in an External Reference using VBA ?
Solved by Alfred.NESWADBA. Go to Solution.
yes, you will have to go into the database of the XRef, then you have access to the blockreference, and so to the attribute-values.
- alfred -
Thank you Alfred.
did you see anthing i missed as in your concept?
After setting filter code & Filter Value, the code:
blkset.Select acSelectionSetAll, , , fitype, fidata 'Debug.Print vbCrLf & blkset.Count If blkset.Count > 0 Then i = 0: j = 0: k = 0 Do While clname = "" And i < blkset.Count Set tmpblk = blkset.Item(i) If TypeOf tmpblk Is AcadExternalReference Then For j = 0 To ThisDrawing.Blocks.Count - 1 Set xrblk = ThisDrawing.Blocks.Item(j) If xrblk.Name = "MYXREF" Then Set xrda = xrblk.XRefDatabase For k = 0 To xrda.Blocks.Count - 1 'For j = 0 To ThisDrawing.Blocks.Count - 1 entname = xrda.Blocks.Item(j).Name If entname = "MYXREF|BLKWITHATTRIBS" Then clname = "MYXREF|BLKWITHATTRIBS" xrtype = "xref" Exit For End If Next k Else If clname <> "" Then Exit For End If End If Next j Else Set blkobj = ThisDrawing.Blocks.Item(tmpblk.Name) xrtype = "block" End If If clname <> "" Then Exit Do Else i = i + 1 End If Loop Else
Vidjeane.M
Thank you Alfred.
the problem is i am not getting clname. it always returns "".
Vidjeane.M
Not tried, but I guess your string to verify the name of the blockdefinition within the XRef might be wrong.
If you open the database from the XRef, you have blocks with names, and as long as in that database there were no XRefs bound the name "MYXREF|BLKWITHATTRIBS" will not be valid, try "BLKWITHATTRIBS" in the "if"-line instead.
If that don't work do a
Debug.Print entname
a line before your if and you see what names are found as blockdefinitions in the XRef.
to come back to your title: this just scans the block definitions within the XRef, it does not access the BlockReferences in ModelSpace (or any other space or blockdefinition if needed)
- alfred -
alfred,
thakn you for your feedback.
will try & update you on this.
regards,
Vidjeane.M
