entmod and sendcommand
I was working on using Sendcommand for entmod of an object but i got really
PO'd and I deleted the entire code. Not a good night.
Can someone post and example code of sending entmod via Sendcommand.
This entity is not editable directly from ActiveX yet so I need to entmod
it.
Rob Starz
Rob@stardsign.com
Plogv 3.0 & 2000 (plot logging) for r14 & 2000
ADT Curtainwall Suite
ADT Restroom Suite
**ADTcadPac coming soon**
http://www.stardsign.com/main.htm <
StarDsign cad solution
What do you need to use (entmod) for in this case?
> it.
> Rob Starz
> Rob@stardsign.com
> ADT Restroom Suite
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
There is a variable in Architectural Desktop Wall entities that is not
available via ActiveX yet. ADT guys have admitted to leaving access to this
out.
So while the entire VBA ap gets all the setting through ActiveX the
CleanupGroup is not and I have to go through Enget of the dxf code. Now
when I want to change this variable I need to Entmod the dxf code of the
wall. PIA but they say it is the only way....for now.
Hi Rob,
You could use the DXF Code 343 directly under the imp_wall object to get
at this. You're right, this should be in the Active X api, sorry!
-Chad
This is the code I have in lisp
(setq e2 (subst (cons 343 ClGroup)
(assoc 343 e2)
e2 )
(entmod e2)
Now to get it to work in Sendcommand
I hate Sendcommand
Rob Starz
Rob@stardsign.com
ADT Restroom Suite
I'm sure I'm missing something but here goes. Will this work?
ThisDrawing.Utility.SendCommand "(entmod (subst (cons 343 ClGroup) (assoc
343 e2) e2 ))" & vbCrLf
Get free software and more at http://www2.stonemedia.com/franko
"Rob Starz" wrote in message
news:8aavil$t2e6@adesknews2.autodesk.com...
this
> out.
> Hi Rob,
get
> -Chad
> (assoc 343 e2)
> e2 )
> (entmod e2)
> I hate Sendcommand
> Rob Starz
> Rob@stardsign.com
> ADT Restroom Suite
I will give this a try on Saturday. Thanks
It is all the """()""""("()) stuff that confuses me. You miss one thing and
it is all shot to hell.
I promise not to delete 3 hours of code anymore.....but it sure felt good to
hit that keyboard hard enought to reboot the system.
Rob Starz
Rob@stardsign.com
ADT Restroom Suite
