divide a region into several regions
Message 1 of 11
hi,
as i know there is not a method to divide a region into several regions,
there is a SliceSolid to solids,but not to region objects,
any hints ,thanks a lot
Replies (10)
Message 2 of 11
maybe ,i have to made a solid using the region ,then slice it
into several solids,then explode the solids to region ,ect,......
boring sub, better avoid this,
"youngman" wrote in message
news:[email protected]...
hi,
Message 3 of 11
It's even worse than that. Unless it is a recent addition, there isn't an "Explode" method for 3dSolids. A "SectionSolid" call is required, with the appropriate set of points describing a plane.
I was able to pull the various elements together to achieve a slice region routine but, as you guessed, it was long and tedious.
Message 4 of 11
THANKS A LOT.
would you please give me the long and tedious subs and funs
thank you in advance
wrote in message news:[email protected]...
Message 5 of 11
I had to collect subs from various modules so bare with me if something is amiss. I'll be away for the rest of the day but will address any problems when I return.
As additional background, this procedure mimicks the 2PTSlice of 2007 for earlier versions. It will slice many of Autocad's 2d elements as well i.e., Region, Circle, LWPolyline, etc.
The 2d elements don't neccessarily need to be coplanar to the UCS.
I welcome all feedback
Message 6 of 11
Thanks a lot.
i havent tried your subs, but, first of all,
thanks for your kindness,SEANT
when I return.
Message 7 of 11
QuillHyde
When I try and implement this, it works great, once.  Then when I run the macro again, Autocad crashes.
Any tips?
thanks!
Quill
Message 8 of 11
QuillHyde
Selection sets!
I copied some code from one of your other examples - the hiding/unhiding code - where you had used a different method for clearing the selection set.  Or something.  I'm a noob at this, but it worked.
Then it got hung up on the delete the original regions code, so I messed around with that.  It gave a code 13 error on the 'if IsObject (varRegs(0)) Then' line - I got it to work by commenting out all the 'if' stuff and just having it run ent2bsliced.delete - it works so far.
good times, learning the hard way.  Thanks for posting the code,  It's a really useful tool for me ... it's going to save me hours and hours of tedious exploding and deleting, and I'll thank you every time.
Quill
Message 9 of 11
QuillHyde
Well, sort of works.  Good enough for now.  Hopefully I'll figure it out eventually
Quill
Message 10 of 11
SEANT61
That is performing poorly in AutoCAD 2009.  It was orignally written for AutoCAD 2004 - Selection Sets may have been handled differently back then.
How does the rest of the module work if this routine is replaced:
Private Sub SSClearST()
Dim colSS As AcadSelectionSet
   'ensure that selection set does not currently exist
   On Error Resume Next
   Set colSS = ThisDrawing.SelectionSets.Item("TempSSet")
   colSS.Delete
   On Error GoTo 0
End Sub
May your cursor always snap to the location intended.
Message 11 of 11
QuillHyde
Yep, that fixed it.
thanks x 10,000,000!
Quill
