hi !
How can I control autocad main windown, becoming it desable to close "x" ?
thanks for atention !
imho you will not get enough funcitonality with VBA to get real full control over the AutoCAD application window. E.g. to avoid that the user closes AutoCAD (what way ever, e.g. TaskManager should not be able to close AutoCAD? Or shot-down-process should not be able to close AutoCAD?).
The most control you will have with a program using Windows-API that plays with processes (watches processes and windows).
- alfred -
Thanks Alfred NESWADBA. I undestood! But is not there anyway to avoid user close de cad main window, programming with vb6 ? Only by windown's API ? Do not you have a code to send me to do it?
I managed to create a lisp function that forces all output to an output that I created. I compiled this function transforming it into a arquivo.vlx that to do AutoCAD startup, does what I need.
Thank you for your attention!
doc_x
