VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
compile error in sub
2 REPLIES 2
Mikexlt
394 Views, 2 Replies
This code worls in c3d 2009 but fails in c3d 2014
Dim oAcadApp As AcadApplication
Set oAcadApp = ThisDrawing.Application
Const sCivilAppName = "AeccXUiLand.AeccApplication.6.0"
Dim oCivilApp As AeccApplication
Set oCivilApp = oAcadApp.GetInterfaceObject(sCivilAppName)
Dim oDocument As AeccDocument
Set oDocument = oCivilApp.ActiveDocument
Compile error
Can't find project or library
Any Suggestions?
Mike
2 REPLIES 2
remy.baud
in reply to: Mikexlt
Hi Mike,
Maybe it is the major/minor version  that you use in the GetInterfaceObject() call.
It's maybe no longer the "6.0" version but another one like (11.0???, 10.3???) and it's maybe why you can't load it.
See this post that is talking about it here.
http://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/discussion/t5/AutoCAD-Ci...
Rémy
Mikexlt
in reply to: remy.baud
Thanks Remy
Changed version to 10.3 and other errors to Object and works fine now
Mike
”Boost
