Hi Mike, I'm aware the way you suggest. However, the dwgs are up to 80 MB or
more, so I'd like to avoid saving. I'm hopefully to find a direct way for
changing the document name.
Goal of my project: Drawings contain 3d objects from a 3rd party
application, which I have to damage and then export filtered objects to
several drawings. It is very important that in no case of error the original
drawing can be overwritten by the damaged data. I'm aware of error handling
of course, but changing the documents name brings additional security.
Kathrin
"Mike Tuersley" schrieb im Newsbeitrag
news:MPG.18d7eb1dfced6e329896b3@discussion.autodesk.com...
> Hi Kathrin,
> Define what you mean by not saving. Simplest method is do a saveas which
> will change the name, then delete the file once you are done with it.
> ___________________________
> Mike Tuersley
> AutoCAD Clinic
> Rand IMAGINiT Technologies
