Visual Basic Customization
New Member
rc28960
Message 1 of 5 (225 Views)
calculating 4th point of a square
225 Views, 4 Replies
09-12-2012 11:27 AM
hello group,
if i have 3 known points, and i know they are 3 of the 4 corners of a square, how do i calculate the 4th? these points are on a skewed square, where the square has been rotated in the x axis and then rotated in the z axis. It must be simple geometry, but i cant see it! any help or pointers to where i should look would be appreciated!
dgorsman
Message 2 of 5 (218 Views)
Re: calculating 4th point of a square
09-12-2012 02:45 PM in reply to: rc28960
Are you working with a rectangle, a square (literally), or a cube?
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Distinguished Contributor
GilesPhillips
Message 3 of 5 (209 Views)
09-13-2012 01:58 AM in reply to: rc28960
Do some websearches on vector maths and/or matrix maths.
You're looking for a math formula that will mirror a point along a line (defined by 2 other points) if you're talking about a true square.  Alternatively you could try looking for a math formula that will copy/translate a point by the distance/vector defined by the two other points - that would create a rectangle or a parallelogram - you would need to do a bit of calculation to make sure you're copying the right point in each case, though there's a 2/3 change you'll get it right at random :smileyhappy:
After that it's just a case of converting it into vba maths. Sorry I don't have time to go into greater detail, but I'd only be looking stuff up on the web anyway.
G
ACad, MEP, 3DS Max
Windows 7x64
X5482 @3.2Ghz 8Gb Ram
Quadro FX1700
New Member
rc28960
Message 4 of 5 (193 Views)
09-15-2012 01:35 AM in reply to: GilesPhillips
thanks guys, ive spent two days net reading, and have a solution, but not really the correct (math) one.
ive constructed a line from pt1 to pt2, then moved it to pt3. the end pt of this line now gives me the co-ordinates i need.
if ive read correctly i think the cross product of a vector is at right angles to the original vector. the vector is the difference between pt1 and pt2.
ill keep reading!
Valued Contributor
bojko108
Message 5 of 5 (182 Views)
09-16-2012 01:13 PM in reply to: rc28960
Here is one solution. Look at the attached picture to see the result. 4th point is cross point of two vectors. It's easy to calculate direction angle between first and third point of the input line and based on this angle and length of the side of the square you can calculate the 4th point. We will have 4 different cases depending on wich quadrant lies the vector between 1st and 3rd point.
Option Explicit
Public Const PI = 3.14159265358979
Sub testche()
    Dim line As AcadLWPolyline       '' input line (constructed by 3 points)
    Dim obj As AcadObject
    Dim var As Variant
    On Error Resume Next
    ThisDrawing.Utility.GetEntity obj, var, "Select line: "
    If (TypeOf obj Is AcadLWPolyline) Then
        Set line = obj
        line = modifyLine(line)
    End If
End Sub
'' this method returns closed polyline
Private Function modifyLine(inputLine As AcadLWPolyline) As AcadLWPolyline
    Dim line As AcadLWPolyline: Set line = inputLine
    Dim pnt1 As Variant: pnt1 = line.Coordinate(0)     '' first vertex
    Dim pnt2 As Variant: pnt2 = line.Coordinate(1)     '' second vertex
    Dim pnt3 As Variant: pnt3 = line.Coordinate(2)     '' third vertex
    Dim pnt4(0 To 1) As Double                         '' fourth vertex
    Dim s As Double: s = getDistance(pnt1(1), pnt1(0), pnt2(1), pnt2(0))
    Dim r As Double: r = 50    '' this is always 45 degrees (50 gon)
Dim a1 As Double: a1 = getDirectionAngle(pnt1(1), pnt1(0), pnt3(1), pnt3(0)) Dim a2 As Double: a2 = getDirectionAngle(pnt1(1), pnt1(0), pnt2(1), pnt2(0)) '' we have four different cases according to rotation of the input line If a1 < 200 Then If a1 < a2 Then a1 = a1 - r Else a1 = a1 + r End If Else If a1 < a2 Then a1 = a1 - r Else a1 = a1 + r End If End If '' coordinates of the 4th vertex pnt4(1) = pnt1(1) + s * Math.Cos(a1 * PI / 200) pnt4(0) = pnt1(0) + s * Math.Sin(a1 * PI / 200) line.AddVertex 3, pnt4 line.Closed = True line.Update modifyLine = line End Function Private Function getDistance(ByVal x1 As Double, ByVal y1 As Double, ByVal x2 As Double, ByVal y2 As Double) getDistance = Math.Sqr(Math.Abs(x2 - x1) ^ 2 + Math.Abs(y2 - y1) ^ 2) End Function Private Function getDirectionAngle(ByVal x1 As Double, ByVal y1 As Double, ByVal x2 As Double, ByVal y2 As Double) As Double Dim alfa As Double If x2 - x1 > 0 And y2 - y1 > 0 Then alfa = Math.Atn(Abs(y2 - y1) / Abs(x2 - x1)) * 200 / PI ElseIf x2 - x1 < 0 And y2 - y1 > 0 Then alfa = Math.Atn(Abs(y2 - y1) / Abs(x2 - x1)) * 200 / PI alfa = 200 - alfa ElseIf x2 - x1 < 0 And y2 - y1 < 0 Then alfa = Math.Atn(Abs(y2 - y1) / Abs(x2 - x1)) * 200 / PI alfa = 200 + alfa ElseIf x2 - x1 > 0 And y2 - y1 < 0 Then alfa = Math.Atn(Abs(y2 - y1) / Abs(x2 - x1)) * 200 / PI alfa = 400 - alfa ElseIf x2 - x1 = 0 And y2 - y1 > 0 Then alfa = 100 ElseIf x2 - x1 < 0 And y2 - y1 = 0 Then alfa = 200 ElseIf x2 - x1 = 0 And y2 - y1 < 0 Then alfa = 300 ElseIf x2 - x1 > 0 And y2 - y1 = 0 Then alfa = 0 End If getDirectionAngle = alfa End Function
You are not logged in.
Ask the Community
