Message 1 of 17
Windows taskbar problem with Autocad 2010 vba enabler in windows 7 x64
06:02 AM
- Mute
- Permalink
- Report
I installed vba enabler on a new computer in order to test out our old vba plotting scripts in windows 7 x64.
The script worked perfectly, but with the vba enabler arose another problem:
Whenever autocad loads the vba subsystem after I use a command like vbaide or vbaload (even without loading any script) Autocad cannot be restored from windows taskbar after minimizing. Not by clicking task bar or by alt+tab. Only way to restore or close it is by using task manager.
Once I restore autocad using task manager it works well, as long as I don't minimize it again. Restarting autocad solves the problem until you load the vba subsystem again. Killing vba server process in taskmanager while autocad is still running doesn't help.
This effectively prevents us from using any the scripts on about a half of the computers in our office.
Has anyone come across this problem?
Any suggestions how to solve the problem?
Edit:
I managed to replicate the problem with vista 64-bit. In vista (unlike windows 7) there is a taskbar context menu option to restore the window, which seems to work. Edited by: anttikauppi3482 on Mar 1, 2010 10:47 AM
Edit:
