VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Why is this sendcommand running asynchronously ?
1 REPLY 1
Arnaud_Lesauvage
709 Views, 1 Reply
Hi all !
Autocad Map 3D 2009 here.
I have writtent a VBA procedure which uses the very unfamous "sendcommand".
I need to retrieve a hatch boundaries. In VBA, AcadHatch.GetLoopAt will return a null array for a non-associative hatch. So I need to retrieve the boundaries and make the hatch associative first. This is also impossible in VBA (AcadHatch.AssociativeHatch can only be set at creation time).
So I thought I'd just issue a sendcommand "_-hatchedit " to recreate the hatch boundaries and associate them to the hatch. (command "_-HATCHEDIT" (handent "<my handle>") "_B" "_P" "_Y") to be more precise.
BUT, to my surprise, the sendcommand runs asynchronously, even though there is no user input in the process.
The autocad help clearly states that "This method is generally synchronous. However, if the command sent with this method requires any user interaction (such as picking a point on the screen) then this method will continue as soon as the user input begins. The command will then continue to be processed asynchronously."
Here is the sample code (just create a non associative hatch in the drawing to test it) :
Sub test()
    Dim oAcadHacth      As AcadHatch
    Dim oSelSet         As AcadSelectionSet
    Dim gpCode(1)       As Integer
    Dim gpValue(1)      As Variant
    Set oSelSet = ThisDrawing.SelectionSets.Add("TEST")
    gpCode(0) = 0:      gpValue(0) = "HATCH"
    gpCode(1) = 71:     gpValue(1) = "0"
    oSelSet.Select acSelectionSetAll, , , gpCode, gpValue
    ThisDrawing.Utility.Prompt vbCrLf
    For Each oAcadHacth In oSelSet
        ThisDrawing.Utility.Prompt "Before : " & oAcadHacth.AssociativeHatch
        ThisDrawing.SendCommand "(command ""_-HATCHEDIT"" (handent """ & oAcadHacth.Handle & """) ""_B"" ""_P"" ""_Y"")& vbcr"
        Application.Update
        ThisDrawing.Utility.Prompt "After : " & oAcadHacth.AssociativeHatch
    Next oAcadHacth
    oSelSet.Delete
    Set oSelSet = Nothing
End Sub
This command does not require any user input, so why is it running asynchronously ?
Thanks a lot for your help !
1 REPLY 1
Ok, self replying.
The problem was not in the macro itself, it runs fine and is synchronous.
The problem was in the way it was called. I used (vla-RunMacro (vlax-get-acad-object) "Test"), and this runs in lisp synchronously so no other lisp command can run until the VBA macro called is finished (that's the way I understand it anyway).
Calling it simple with -VBARUN "Test" works just fine !
”Boost
