Hi to everybody,
For a long time I faced with some kind of problem. I load some vba project it works fine, there is no error on the code.
But when I load vba from load/unload aplication, acad runs very very slow. In previous versions of acad
like 2010, 2009 the problem did not couse any disturbance because slowing down of the program can not be realized.
However in 2011 and 2012 versions slowing down is very annoying. Is there a solution for that? Has anyone face with some
kind of problem like that or any ideas what may be cause to that problem?
Solved by tomhurns. Go to Solution.
Solved by Alfred.NESWADBA. Go to Solution.
let me guess, with AutoCAD release 2011 you changed to an 64bit operating system?
If so ... that's the reason,
- alfred -
Yes it is 2011 release I use 64 bit oprating sysytem.
Is operating system cause to that?
Yes and no. The OS does not really cause VBA to be slower, the reason is, that there is no VBA for 64bit available from Microsoft, they did it just for 32bit and say if you have 64bit change to dotNET and that's it.
Autodesk did now a trick to have it at least working, the create a separate 32bit-process doing the VBA-job and from 64bit-AutoCAD it sends all traffic through the operating-system to the 32bit-VBA, and every request from the VBA-process to any AutoCAD-geometry/variables/properties.... are also sent from the 32bit-process via operating-system to AutoCAD.
And this (out-of-process) handling is very slow compared to running in a 32bit within the process of AutoCAD.
- alfred -
Thank you very much,
This information is very useful to me. I hope in a near future they will do something for 64 bit systems.
I have the same problem for AutoCAD 2010 - is there a solution yet? My VBA is unusable now, I need this solved ASAP - please someone can you help me?
If you are dependent on VBA, in AutoCAD 2010, then by far the best solution is the Longbow Converter tool. I'm using it and I can assure you that my VBA runs as normal on 64bit Windows 7
Tom
Thanks Tom, I tried the Longbow Converter and now everything is running perfectly again.
