Vba code wanted
Vba code wanted
john
Vba code wanted
john
Hi all,
I would like to know if anyone has some code that they would like to share.
What i am looking for is something that would allow be to auto number a particular attributte within ablock on a drawing
The block attribute would be called ID and i would like to run the code and then just go around and select the first instance of the block, set a starting number and have it incrementally continue numbering from that number on as i select the blocks thereafter.
The block  which is a component id mark would generally have about 10 attributes and only 1 of them is needed to be changed.
Thanks in anticipation
John B
Hallex
Give this a shot
{code}
Option Explicit
'Tools --> Options --> General tab --> Error Trapping --> Break on Unhandled Errors
    Sub Block_Renumbering()
    Dim bRef As AcadBlockReference
    Dim pick As Variant
    Dim atArr As Variant
    Dim oAtt As AcadAttributeReference
    Dim aTag As String
    Dim i As Integer, k As Integer
    On Error GoTo ProblemHere
k = CInt(InputBox("Enter initial number:", "Block Renumbering", 1))
    Do
    ThisDrawing.Utility.GetEntity bRef, pick, "Select a block reference"
    If Err <> 0 Then
        Err.Clear
        MsgBox "Program ended.", , "Block Selection Error"
        Exit Sub
    Else
        atArr = bRef.GetAttributes
        For i = 0 To UBound(atArr)
        Set oAtt = atArr(i)
        aTag = oAtt.TagString
        If aTag = "ID" Then
        oAtt.TextString = k
        k = k + 1
        Next
Loop Until Err.Description Like "keyword"
ProblemHere:
    End Sub
{code}
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
truss_85
Hi John,
here is what you want I suppose...
Public Sub att_sort()
Dim waz As String
Dim pt As Variant
Dim xy As Variant
Dim objBlock As AcadBlockReference
Dim var_atts As Variant
On Error Resume Next
ThisDrawing.SelectionSets.Item("SS1").Delete
Dim ssetObj As AcadSelectionSet
Set ssetObj = ThisDrawing.SelectionSets.Add("SS1")
Dim FilterType(0) As Integer
Dim FilterData(0) As Variant
m = ThisDrawing.Utility.GetReal("Enter a number to start:")
m_s = ThisDrawing.Utility.GetString(True, "Enter a prefix:")
FilterType(0) = 0
FilterData(0) = "INSERT"
ssetObj.SelectOnScreen FilterType, FilterData
n = 0
For Each Item In ssetObj
Set objBlock = ssetObj.Item(n)
var_atts = objBlock.GetAttributes
    For i = 0 To UBound(var_atts)
        If var_atts(i).TagString = "TYPE HERE ATTRIBUTE NAME" Then
            var_atts(i).TextString = m_s & m
            m = m + 1
    Next
n = n + 1
Next Item
End Sub
truss_85
Faster then me 🙂
I did not see your post
Sorry...
Hallex
It's good to allow to choose user what he needs 🙂
~'J'~
john
Hallex,
Thanks for that it worked a treat. Exactly what i was looking for.
Regards
John
Hallex
You're welcome
Happy coding 🙂
Oleg
