- Mute
- Permalink
- Report
Hi all,
I would like to know if anyone has some code that they would like to share.
What i am looking for is something that would allow be to auto number a particular attributte within ablock on a drawing
The block attribute would be called ID and i would like to run the code and then just go around and select the first instance of the block, set a starting number and have it incrementally continue numbering from that number on as i select the blocks thereafter.
The block which is a component id mark would generally have about 10 attributes and only 1 of them is needed to be changed.
Thanks in anticipation
John B
