VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
VBA on AutoCAD 2012 64 bit?
23 REPLIES 23
Message 1 of 24
muckmailer
4943 Views, 23 Replies
I have recently upgraded form AutoCAD 2010 to AutoCAD 2012 (64 bit). I am using the 64 bit AutoCAD enabler. I noticed that my VBA routines on this new will not run properly. Text Field that I typed data into will not allow me to enter data. Is there a fast solution to this problem that does not envolve recoding? Thank you,
23 REPLIES 23
Message 21 of 24
muckmailer
in reply to: muckmailer
For short term the only solution I have is to convert my drawings to an older version of cad and
then run my rountines with the older version.  Yes AUTOdesk a down grade is a better option.
Why did AutoDesk put an VBA enabler in 2012 (64bit) if is does not work????
Still looking for a real short term solution
Waiting for advise.
Thank you
Message 22 of 24
muckmailer
Would there be a way to set focus or to that form or tool box?
Maybe that is the problem?
Thank you,
Message 23 of 24
muckmailer
Would there be a way to set focus or to that form or text box?
Thank you,
Message 24 of 24
muckmailer
I found it.
This will fix my problem.
  1. Open the Project window of the VBA IDE and select the project you want to add the form to.
  2. From the Insert menu, choose UserForm, and change the ShowModal property to False.
  3. Add the AcFocusCtrl (AcFocusCtrl.dll) to the Toolbox, and drag the control onto the form.
    The AcFocusCtrl keeps the focus on the form during user interaction.
Now is is time to find the next 64 bit issue
Thank you,
”Boost
