Using VB program to insert AutoCAD block
Currently using AutoCAD 2010
Inside VB, under references I have selected AutoCAD 2010 Type Library and AutoCAD/ObjectDBX Common 18.0 Library.
I created a titleblock insertion program for our projects which has been working fine in AutoCAD 2008
Part of code where it crashes:
Public Sub InsertBorder(DwgBlock As String)
  Dim Inspt(0 To 2) As Double
  Dim XYZScale As Double
  Dim Rotation As Double
  Dim varAttribute As Variant
  Inspt(0) = 0
  Inspt(1) = 0
  Inspt(2) = 0
  XYZScale = 1
  Rotation = 0
  'set border layer to SHEET01
  Set objCurrentLayer = acadDoc.Layers.Add("SHEET01")
  acadDoc.ActiveLayer = objCurrentLayer
  ;code crashes on the next line. In Debug mode, I discovered that the variable Inspt has no value, all other variables are
  Set objBRef = acadDoc.ModelSpace.InsertBlock(Inspt, DwgBlock, XYZScale, XYZScale, XYZScale, Rotation)
Any suggestions will be greatly appreciated. I am guessing there is a change with AutoCAD 2010, but hell if I can find it.
wayne.brill
I am not aware of a change to the ActiveX API method InsertBlock() that would explain why the error is occurring. Can you try simplifying your code to narrow down the cause of the error? You could use this VBA example that does something similar to your code. It uses ThisDrawing to instantiate acadDoc variable. (change the path to a dwg on your system)
Public Sub wbtest()
    InsertBorder ("c:\temp\wbtest.dwg")
End Sub
  Inspt(0) = 0
  Inspt(1) = 0
  Inspt(2) = 0
  XYZScale = 1
  Rotation = 0
  Dim acadDoc As AcadDocument
  Set acadDoc = ThisDrawing
  ' This is working on my system
End Sub
Wayne Brill
Wayne Brill
Developer Technical Services
Autodesk Developer Network
