Visual Basic Customization
Active Member
Mihai
Message 1 of 4 (90 Views)
Troubles with ByRef and ByVal in VBA
90 Views, 3 Replies
12-03-2003 02:56 PM
I cant figure why this didn't work:
Public Sub MainAppeal()
Dim Var As Integer
Var = 1
Apelat (Var)
MsgBox Var
End Sub
Public Sub Apelat(ByRef arg As Integer)
arg = arg + 1
End Sub
Variable Var should become 2, isn't it?
Is there a restriction in VBA or I don't know how to use.
*Bombrowski, Kathrin
Message 2 of 4 (90 Views)
Re: Troubles with ByRef and ByVal in VBA
12-03-2003 04:26 PM in reply to: Mihai
Good morning Mihai,
The latter seems to be the case, sorry.
IMHO there are 2 possibilities:
First: have the Apelat sub to be a function. A function returns a value (or
object ...), a sub doesnt.
Dim Var As Integer
Var = 1
Var = Apelat(Var)
MsgBox Var
End Sub
Public Function Apelat(ByRef arg As Integer)
Apelat = arg + 1
End Function
second: you may declare Var to be public and use the Apelat sub to change
Var directly.
Public Var As Integer
Var = 1
Apelat
MsgBox Var
End Sub
Public Sub Apelat()
Var = Var + 1
End Sub
For Byval vs. ByRef see the Help file -do a search for "byval", theres a
topic named "efficient handling of arguments" or something like that (I have
the german version).
*Oquendo, Frank
Message 3 of 4 (90 Views)
12-03-2003 09:20 PM in reply to: Mihai
Remove the parens in your call to Apelat and everything will work as
exepcted. This is a case of VB/A's flexibility getting in the way.
Consider this:
Apelat Var
Call Apelat(Var)
Both yield the same result. However, this does not:
Apelat (Var)
When you surround a parameter with parens and don't use the Call
keyword, VB/A passes a copy of that parameter. So even though you
specified the parameter is to be pass ByRef, you're essentially passing
ByVal as the copy is sent and modified, leaving the original untouched.
There are 10 kinds of people. Those who understand binary and those who
don't.
http://code.acadx.com
(Pull the pin to reply)
Active Member
Mihai
Message 4 of 4 (90 Views)
Re:
12-08-2003 05:10 PM in reply to: Mihai
Thanks Frank. It takes a little to understand that is about calling method but now you confirm that. Unfortunately, this is not mentioned in my online help, so I have to keep this in mind |:smileysad:.
You are not logged in.
Ask the Community
