Hi every one,
I have a VBA marco which opens (one by one) all the DWGs in a specific folder and subfolders.
After opening and closing a few files, Autocad needs a least 5 minutes until the file is opened.
Actually I think that at that point the file is already loaded and opened.
Autocad seems to be checking something in background (not part of my macro).
As I have +/-2200 files to open and apply some changes to them with the macro, it would take 2200 files * 5 minutes = 11000 minutes (= 183 hours or 7 days).
The part of the macro which applies the changes to the drawing just last for less than second.
The macro looks like this (reduced for message propose...):
Sub ListSubFolder(subFolders As Scripting.Folders)
Dim fileItem As Scripting.File
Dim subFolder As Scripting.Folder
For Each subFolder In subFolders
If subFolder.subFolders.Count > 0 Then
ListSubFolder subFolder.subFolders
End If
If subFolder.Files.Count > 0 Then
For Each fileItem In subFolder.Files
If fileItem.Type = "AutoCAD Drawing" Then
' this is the line where the waiting takes place...
ThisDrawing.Application.Documents.Open fileItem.Path
' on the COMMANDLINE I see that the file is opened.
' from this point on nothing seems to hapen expept that the CPU usage is at 100%
' and Memory usage at it's maximum.
' the computer gets so slow that all I can do is sit and wait (like Sydney Youngblood...)
currFilename = ThisDrawing.Name ' for later control in macro
' run my macro here, it takes less than a second to step to the next line
ThisDrawing.Save
End If
Next fileItem
End If
Next subFolder
End Sub
So if someone knows why this is like it is until I get retired, I would be very happy and pleased.
Thank you.
hi mendesva,
I too have a similar code(don't have it today..it is at my office computer)
i have used some logic similar to the one below for recognising autocad file..this may be faster to the filetype method..my files are opening rather fast using this..try it..will get full code if u want on monday..
If Right(fileitem.path,3) = "DWG" OR Right(fileitem.path,3)="dwg" Then
Thank you
Vinayan
Hi guys,
Just a small correction to your code and explanation why I would do it.
Instead of:
I would use:
If UCase(Right$(fileitem.path, 3)) = "DWG" Then
Just some proper programming techniques I thought I'd share. Have a great day guys! =D
Just an idea...
You might want to create an array of file names before and then loop through this array
(FileSystemOBject must be released after this point)
It may helps I think
~'J'~
Much more than your code could be causing this problem. Just some thoughts ...
Could there be missing xref issues?
is there a hidden dialog box?
Any Autolisp code running on some drawings, not others?
Network traffic issues?
do the file paths have urls or mapped drive references?
could the mapped drive be auto-timing out?
if the dwg files are rather large, you may need to put a wait-timer in between opening and closing the files to allow natural behind the scenes stuff to occur.
can the drawings be opened and modified in a minimized state for the macro to work? professional experience proves drawings can be automated much quicker when minimized and rendering not required.
